Blinking Drive-3 Indicator?
Old Sep 13, 2010 | 01:28 PM
bazoOKA_ TOoth's Avatar
Default Blinking Drive-3 Indicator?
Hey guys,
My dad just bought a 91 integra. It has an automatic transmission and I recently received a call from him telling me that the instrument panel had the outline around the D3 icon blinking at random times. Do u guys know what the problem might be?
Thanks in advance.
Old Sep 13, 2010 | 03:23 PM
follie gatts's Avatar
Default Re: Blinking Drive-3 Indicator?
Originally Posted by bazoOKA_ TOoth
Hey guys,
Thanks in advance.
a bad ground caused a blinking d4 light in my 2000 ls
Old Sep 15, 2010 | 06:28 PM
Where was that ground on your car? I want to find it on my car.
Old Sep 16, 2010 | 04:56 PM
are you also showing a CEL? mine blew a fuse each time the AT tried to shift. the incomplete ground was the negative battery terminal to the chassis.
Old Sep 16, 2010 | 05:06 PM
use a voltmeter that can check for continuity between two points on a circuit. use it on the the 3 major grounds from (battery, valve cover and transmission) to chassis.
Matt Royer Jr.
Mar 23, 2013 01:52 PM
EJ1_CRIS_909
Mar 8, 2012 08:35 PM
gus straussen
Jan 3, 2011 07:05 PM
superslowhatch
Jan 15, 2003 07:58 AM
