Type R ECU?!
Old Sep 16, 2010 | 12:49 AM
-__-'s Avatar
Default Type R ECU?!
I'm going to be dropping in a motor i'm rebuilding and was wondering if this ECU would be good. it's a 97 Spec ITR ECU. P73-003
The block is a JDM B18C (GSR/SiR-G) NOT TYPE-R!
The head is a B16 PR3 head.
this setup will run about a 10.5 Compression ratio.
so i was wondering if the Type-R 11:1 compression ratio ECU will run this motor well?
If anything it will run it better than my USDM GSR computer.
your thoughts? thanks a lot.
Old Sep 16, 2010 | 07:57 AM
'00_GSR/R's Avatar
Default Re: TYPE-R ECU?!
USDM ITR is 10.6 or .8, and JDM ITR is 11.1. So a USDM ITR would be a closer tune to your 10.5, but with a USDM ecu you will need all the sensors. Your better off with a custom tune.
Old Sep 16, 2010 | 05:14 PM
-__-'s Avatar
Default Re: Type R ECU?!
yeah the USDM one would be better. I can only find a JDM one for now. thanks a lot for ur reply.
b18c5 power
Nov 21, 2011 07:24 PM
broken_machine
Mar 26, 2004 08:17 AM
