Pressure plate??
Old Sep 18, 2002 | 02:30 PM
EightOhOne's Avatar
Default Pressure plate??
im in the process of swapping out my clutch/pp and have a quick question. should the pressure plate sit flush on the flywheel before torquing it down to spec? mines got like 3/16 of an inch between the pp and the flywheel. All 3 dowels are aligned right and everything. the bolts are about finger tight right now, i just dont want to torque them down if its gonna fawk my clutch disk up...any suggestions? maybe i got the wrong PP?
Old Sep 18, 2002 | 03:11 PM
Rocket's Avatar
Default Re: Pressure plate?? (EightOhOne)
That's correct. When you you are torquing down the bolts and closing the gap that's when the diaphram is being loaded with pressure to hold the disc.
3/16 also happens to be the thickness of the disc.
Old Sep 18, 2002 | 04:25 PM
EightOhOne's Avatar
Default Re: Pressure plate?? (Rocket)
thanks a lot rocket, you're the man
Old Sep 19, 2002 | 05:06 PM
lightning's Avatar
Watch the fingers on the plate as well they will start to move inward, kinda cool.
Johnmadsen
Feb 11, 2019 07:19 AM
mjshealy
Jul 26, 2009 03:34 PM
hayabusa160
Jun 18, 2008 01:28 PM
mikegeezy
Mar 21, 2006 09:58 AM
