ITR guage cluster into '93 GSR-do wires fit?
Old Sep 18, 2002 | 02:02 PM
LS-Rt's Avatar
Default ITR guage cluster into '93 GSR-do wires fit?
I want to put an ITR cluster into my '93 GSR. Does anyone know if the wire connectors on the back of the cluster will match? Which other connectors will fit into the back of the ITR cluster such as maybe G3 GSR, civic si...?
Thanks
Old Sep 18, 2002 | 02:22 PM
RedlinedVTEC's Avatar
Default Re: ITR guage cluster into '93 GSR-do wires fit? (LS-Rt)
I have a GSR cluster in my coupe, you have to switch around 15 wires or so, not to hard, you'll also have to modify either the cluster itself or the plastic surround on the dash. Pretty easy install if you're good with a dremel and a soldering iron.
Old Sep 18, 2002 | 02:24 PM
LS-Rt's Avatar
Default Re: ITR guage cluster into '93 GSR-do wires fit? (RedlinedVTEC)
What year is your car and the new cluster?
Old Sep 18, 2002 | 04:44 PM
LS-Rt's Avatar
anyone?
Old Sep 18, 2002 | 06:58 PM
VTECVillain's Avatar
I've never compared the 90-93 cluster to the 94+ cluster. I know that the plugs are different. If you can make it fit and get the plugs for the newer cluster, then a little rewiring and it should work with no problem. I had a 96 GSR cluster in my 92 VX but I changed it back to stock because of the fitment issues. it looked good (other than fitment) and I had it wired up to where everything worked properly.
KILLAB17VTEC
Feb 20, 2010 07:21 AM
20-EM2-05
Honda Civic (2001 - 2005)
Aug 20, 2009 12:14 PM
4dooritr
Jun 2, 2008 08:07 PM
allnapower
Feb 24, 2005 02:03 PM
rkn527
Mar 26, 2003 06:46 PM
