ignition/starting problem
Old Sep 12, 2010 | 01:25 PM
nasty_94_gsr's Avatar
Icon6 ignition/starting problem
ok first what the car is doing. when i turn the key the lights come on but thats it. what i have tried. 1. replaces the clutch pedal switch, 2. replaces starter, 3. replaced the ignition switch. i have tried 3 different starters. i can short out the starter and/or push start it and it will fire up every time. i am just running out of ideas on what it could be. if anyone has any ideas please post them.
Old Sep 12, 2010 | 02:42 PM
Blah.'s Avatar
Default Re: ignition/starting problem
check your alternator. and maybe check the ignition and starter wiring under your steering wheel to see if its loose
Old Sep 12, 2010 | 03:03 PM
ok thanks, i will check the wires right now and have the alternator checked tomorrow when i go to work.if both of those are good then what? In my mind my next step would be to rewire the whole ignition system and put in a push button or a toggle ignition. but dont really want to do this if it is not the problem.
Old Sep 15, 2010 | 08:01 AM
ok update on my 94 GSR. starter good,wires good/tight,all relays and fuses good,clutch pedal switch good but still wont fire with out push starting and/or shorting out starter. i am out of idea please give me your ideas
freshvibes
May 3, 2009 11:05 AM
chunk3rs
11
Jun 6, 2007 11:58 AM
OPTION2ek V.2
Jul 7, 2005 05:56 PM
JDMSloLude
Dec 25, 2004 03:44 PM
bboy21385
Dec 2, 2004 10:45 PM
