ignition/starting problem
ok first what the car is doing. when i turn the key the lights come on but thats it. what i have tried. 1. replaces the clutch pedal switch, 2. replaces starter, 3. replaced the ignition switch. i have tried 3 different starters. i can short out the starter and/or push start it and it will fire up every time. i am just running out of ideas on what it could be. if anyone has any ideas please post them.
ok thanks, i will check the wires right now and have the alternator checked tomorrow when i go to work.if both of those are good then what? In my mind my next step would be to rewire the whole ignition system and put in a push button or a toggle ignition. but dont really want to do this if it is not the problem.
ok update on my 94 GSR. starter good,wires good/tight,all relays and fuses good,clutch pedal switch good but still wont fire with out push starting and/or shorting out starter. i am out of idea please give me your ideas
OPTION2ek V.2
Jul 7, 2005 05:56 PM
