HELP!!! z6 problems
I can not figure out what is going on with my z6 when i try to crank it, it tries to turn over but all it does is blow a bluish smoke from the intake manifold (throttle body) and i need to find out what it is can anyone help me please
thanks
ttt
thanks
ttt
What are you running obdo or 1, I had a problem with the dizzy being upside down and the wires all flopped around, I was having the same problem...massive intake farts. Once I got everything right it ran perfect. Has your car been running or did you just do the swap?
We just did the swap, its non obd, and if its not timing what could it be? The motor came o ut of a running car, we did a swap in that guys car like 2 weeks ago so...
Did you cut the dizzy with a dremmel or something so that it sits up right or did you just spin it upside down so that two of the holes line up?
[Modified by TEAM GARAGE SHIFTDOWN, 3:34 AM 9/19/2002]
One hole with no modification? If so cut the dizzy so that it will site up right like stock. Soudn like you firing at the wrong time causing the intake farts. After I got my dizzy the rigth way all my problem went away. I will post a pic so you can look atfer i get home from school.
Electron00
Apr 24, 2005 11:07 AM
