emissions help
I have a b16a in my civic and it just failed emissions:
I replaced the plugs, cap and rotor, and catalytic converter before going for the test. Anybody ever have similar problems or advice??
what polution did u fail?its probably o2 sensor or egr valve.use 93 octane.also take off a vaccum line off the intake manifold cap off that line take a spare piece of vaccum line run it to the spot you just pulled off the intake manifold put about a quarter of a bottle of transmission fluid in a small jar.put the spare piece of vaccum in the trans fluid strat the car w/the vaccum line in the trans fluid rev the engine to about 5grand there should be a ton of smoke coming out of the tail pipe keep the engine up at 5 grand til it stops smoking then hook the vaccum line back up.then put the rest of the trans fluid in the engine oil.run for about a week then get the oil changed.the engine internals are all cleaned now.run for about a week using fuel injector cleaner.
i failed mine today.
Hydrocarbons (HC):
standard: 220.00 ppm
vehicle results: 446.05 ppm **Failed**
Carbon Monoxide (CO):
standard: 1.20%
vehicle results: 0.39% **Passed**
I'm guessing its the Primary o2 sensor. Since, on the way home got a CEL for the primary o2. A friend of mine is bringing me another one tomorrow. Then I'll go give it a shot.
Hydrocarbons (HC):
standard: 1.20%
use an adjustable fuel pressure regulator, turned down to 25 psi, use ZFR4F-11 NGK plugs (they're the hottest heat range plugs). And that should do it. I passed the sniffer here in cali with a b16, new cat, MSD SCI ignition, NGK ZFR4F-11 plugs, and FPR turned down. She blew cleaner than the stock HF motor. Good Luck
Hydrocarbons (HC):
standard: 1.20%
Hydrocarbons (HC):
standard: 1.20%
any problems by running a stock SI ECU with the B16 all wired up? i figure that if the vtec solenoid, switch, and knock sensor are all wired into the ecu plugs, the SI computer might get a wrong signal?? does the SI computer just have weak fuel and timing maps?
Last I checked, you can't have an adjustable fpr for CA smog. What about other states?
%CO2 idle-meas 14.9
2500 rpm-meas 14.9
%O2 idle-meas 0.0
2500 rpm-meas 0.0
HC idle-max 120, ave 0029, meas 17
2500 rpm-max 140, ave 0020, meas 19
CO idle-max 1.00, ave 00.10, meas 0.00
2500 rpm-max 1.00, ave 00.10, meas 0.01
Results: PASS
Once again this is a Cali smog sheet, so if any one know how to translate please do so. On my wifes CRX it was 90 JDM b16, Tanabe Hyper-medallion exhaust, new cat, MSD SCI ignition, MSD wires, ZFR4F-11 NGK plugs, FPR (@25psi), Timing stock. Also make sure that on your ECU you swap the purge cut-off solenoid from it stocks location A6 to A10. This was intresting since I paid close attention to the JDM clips off of a PR3 ecu and A6 had no terminal, but A10 did, now I found that on the HF wiring A10 pin is for the EGR and the on the Si it the Fast Idlve solenoid. B16 don't have an EGR or a Fast Idle solenoid. So hmmmm, I've wondered why no one else found this out.
[Modified by MrDoHc2, 7:10 AM 9/19/2002]
4crx4me
Jun 15, 2004 08:56 AM
I passed a ZC a while ago. Thanks for the help.
