Plz help miss fire problem
Old Sep 10, 2010 | 05:14 PM
clowery89's Avatar
Default Plz help miss fire problem
ok iv tried every thing i tested it ... its a miss fire on cyl 3 but its olly when i start it for about 30secs. unless i give it gas then it smooths out till the next time i turn it off repleced injectors new wire spark plugs are fine..... idk any ideas anything will be helpfull at this point
Old Sep 10, 2010 | 05:53 PM
phootbag's Avatar
Default Re: Plz help miss fire problem
Head gasket failure?
Old Sep 10, 2010 | 06:34 PM
clowery89's Avatar
really? well then why would id be fine after warm up
Old Sep 10, 2010 | 06:47 PM
redbull-1's Avatar
Have you checked the condition of the distributor cap?
Old Sep 10, 2010 | 07:13 PM
clowery89's Avatar
yeah i cleaned it out today it looks good i mean alittle dusty thats all
Old Sep 10, 2010 | 07:43 PM
CRX Si69's Avatar
hows your timing? my timing was off a bit and it was miss firing at low rpms, but after it warmed up and at higher rpms it didnt miss..
Old Sep 10, 2010 | 08:42 PM
clowery89's Avatar
ill check the timing tommorrow
Old Sep 10, 2010 | 09:06 PM
phootbag's Avatar
Sometimes a headgasket failure can cause misfires during startup and for a short time after until the coolant that has leaked into the cylinder overnight has cleared out.
Don't confuse a suggestion for diagnostics.
Old Sep 10, 2010 | 09:35 PM
clowery89's Avatar
ok i get it well .... i dont wanna hope for the worst yet .. but if that is it how long would you say i have to fix it cause right now its all i have to drive and what all will i need to do it myself ...
Old Sep 11, 2010 | 12:43 PM
phootbag's Avatar
As you say, I wouldn't jump to conclusions. You need to diagnose it. I was only throwing that out there as an idea.
It's not really hard to do yourself. Torque specs are important.
Old Sep 11, 2010 | 12:56 PM
USDM sI's Avatar
"phootbag" is right
its happened to me many tmes and for the most part always been timing but the head gas. is a big possibility too
Old Sep 11, 2010 | 08:25 PM
clowery89's Avatar
well ill check timing but if not i am pulling the head off i stuck a long rubber hose in the chamber in the spark plug hole and it came out with a little coolent and its only getting worse day after day as for specs i got it torque specs i have alll the tools ill need dads AMP mech
Old Sep 11, 2010 | 11:08 PM
USDM sI's Avatar
Coolant in the combustion chamber? bro you got a bad head gasket and or a warped head
but one other thing... if the coolant is only in number four ill bet its the intake mani. gasket.
Old Sep 11, 2010 | 11:13 PM
clowery89's Avatar
no right now its only hitting # 3
Old Sep 11, 2010 | 11:35 PM
USDM sI's Avatar
warped head and or head gas. does your spark plug have a white substance on it
Old Sep 12, 2010 | 02:07 PM
clowery89's Avatar
i have the motor half apart now i cant get the power steering bracket off the head its pissing me off.... and no the plugs look new like they are as of a few weeks ago i stuck a rubber hose in the #3 cyl and i got green coolent at the end so i just said **** it im pulling it apart ...
Old Sep 12, 2010 | 02:25 PM
USDM sI's Avatar
like i heard before on this site...
dont guess, troubleshoot
Old Sep 12, 2010 | 04:13 PM
clowery89's Avatar
yeah ok got the brackets off but the head bolts wont come off are they reverse threaded
Old Sep 12, 2010 | 04:24 PM
hardhitta's Avatar
bump
Old Sep 12, 2010 | 04:37 PM
phootbag's Avatar
No. They are just tight as a motha
Old Sep 12, 2010 | 09:36 PM
clowery89's Avatar
i got them off lol busted my hand hurt like a mother but ill live shouuld i replace the intake mani gasket while i have it all apart
Old Sep 13, 2010 | 01:55 AM
USDM sI's Avatar
yes whatever you take apart. if it has a gas. replace it
the only thing i have gotten away wih but i wouldnt advise it (unless its metal, and it still should be done) is the exhaust mani gasket
Old Sep 18, 2010 | 11:47 AM
clowery89's Avatar
ok can some one please send me a pic of where the cam is when at TDC
TachiKun
Mar 28, 2016 11:28 AM
2wheelhunter
23
Jun 30, 2008 08:23 PM
ef_hopeful
Jan 28, 2008 07:10 PM
SoHc94
22
Aug 26, 2006 09:18 PM
FourthGenHatch
May 22, 2003 09:45 PM
