Another Idle Problem *Searched*
Old Sep 10, 2010 | 03:21 PM
StreetRacinThug's Avatar
Default Another Idle Problem *Searched*
1995 Honda Civic Si hatch
1997 JDM B18B
I/H/E
P75 Virgin
NO CEL
I did a full tune up with NGK wires and plugs.
CLEANED AND REPLACED IACV
Set ignition timing to 16
Did a compression check 180 across the board
Changed throttle body
All parts were new or changed with existing new ones
There is no vacuum leaks car idled great for about 2-5 minutes then it does this hiccup or misfire coolant is bled and at a good level please help. Video up shortly
youtube.com/watch?v=vv6y2eM1pr4 thanks guys
Old Sep 10, 2010 | 03:51 PM
Former User's Avatar
Default Re: Another Idle Problem *Searched*
Is this an idle specific problem or does the engine also have some issues while driving?
Is this a hunting/fluctuating idle? Does the idle spend more time on the high side or the low side of idle speed?
Old Sep 10, 2010 | 10:00 PM
EgUnoGodfather's Avatar
I did the Fitv cleaning thanks to RonJ@ht it worked like a charm
Old Sep 11, 2010 | 08:59 AM
It spends more time about high idle but once it starts its about half and half. I guess it doesnt miss when im driving...unless I drive for a very long time I somewhat feel of a performance issue maybe.
Old Sep 11, 2010 | 09:11 AM
I cleaned my IACV but not as well as your write up explains. I will be doing both the IACV and the FITV tomorrow thanks for your write ups RonJ@HT. Do you have a shop down in Houston or something? I am from Houston but live in Maryland right now.
decon
Dec 19, 2012 07:57 PM
Civicfanatic_09
17
Jul 16, 2012 12:04 AM
hell0curry
Apr 4, 2012 11:20 PM
diLUDEd
Aug 22, 2002 10:08 PM
