high compression question
Old Sep 9, 2010 | 05:53 PM
91tegrsjg's Avatar
Default high compression question
I have a 86mm 13:1 motor and im looking for the best affordable header i can find any imput?
Old Sep 9, 2010 | 06:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: high compression question
your thread title and question really aren't related. What do you consider "affordable"? What motor is it a B series or what? Best for what? daily driving? autocross? drag?
Better questions gets you better answers.
Old Sep 10, 2010 | 07:42 AM
91tegrsjg's Avatar
sorry. im looking at the 600 range. I have a gsr sleeved at 86mm with wiseco 13:1 pistons on treated ls rods. itr head that is ported. and running crower 402-2 cams. its gonna be a daily driver/ weekend warrior
Old Sep 10, 2010 | 07:47 AM
turtleman321's Avatar
What lol 13:1 is not gonna happen on pump gas. And why the stock rods? An those cams aren't enough for that compression
Old Sep 10, 2010 | 08:40 AM
91tegrsjg's Avatar
stock rods as of now i just need to get the car running im looking at getting eagle rods with some deployment money. also a new header and cams. i am already set on buddy club IIIs. i just need a header
Old Sep 10, 2010 | 08:51 AM
91tegrsjg's Avatar
and kingmotorsports did an lsv with 13:1 on pump made pretty decent power
Old Sep 10, 2010 | 08:57 AM
mar778c's Avatar
Community Builder
Community Influencer
Let me ge this straight;
DD, 86 mm, and 13:1 on BC3s. You have got to be kidding.
86 mm is race engine only bore size.
BCIII are for stock compression motors.
Old Sep 10, 2010 | 09:00 AM
91tegrsjg's Avatar
the what move to BCIV
Old Sep 10, 2010 | 09:01 AM
91tegrsjg's Avatar
look im not trying to be an *** im a newb to all motor
Old Sep 10, 2010 | 09:29 AM
fv8s's Avatar
to answer your question you can get a hytech rep. header for around $400 and make some nice power gains.
as far as your setup goes.... good luck. thats not an ideal setup for a "daily driver". that high of compression needs some type of race gas and more agressive cams. You may have some rod bending problems down the road, and when a rod does bend (which it will) i suggest lowering that compression a tad if you want to make the car streetable.
Old Sep 10, 2010 | 09:37 AM
92TypeR's Avatar
FSAE
You will need a cam with large primaries to help reduce your dynamic compression. Skunk2 Pro-2's or Pro-3's would be my first pick. Of the cams I've tested, these have been the best performers.
13:1 with Pro-3's is very do-able with 92 octane and careful tuning. I am at close to 12.5:1 on Pro-3's, and I can reach MBT on my ignition advance at peak torque before knock limit. Even high-load low-RPM zones are not an issue. When I broke the motor in using ITR cams, I was knocking a lot in that zone, just too small of a cam.
Hope that helps.
Old Sep 10, 2010 | 09:43 AM
black jdm type R's Avatar
skunk pro series stage 2 cams, hytech replica headers and 2.5 to 3 exhaust, should be fine for a daily driver.
redhondacivic
Jun 10, 2006 01:57 PM
Superdragr45
11
Dec 20, 2004 01:37 PM
98itr543
Oct 30, 2002 11:38 AM
dorkydavid
Aug 17, 2002 12:34 PM
