Honda CR-V & Element 2WD & 4WD Element & CR-V
98 honda crv engine error codes
Old Sep 8, 2010 | 07:46 PM
laloquera916's Avatar
Default 98 honda crv engine error codes
Im flashing three error codes 73, 74 & 45. Anyone know where I can look this up? Gratz!
laloquera916
Old Sep 8, 2010 | 08:35 PM
Default Re: 98 honda crv engine error codes
11 views and no feed back, anyone?
Old Sep 8, 2010 | 09:56 PM
DCRB's Avatar
found here...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/all-ecu-codes-you-will-ever-need-1710584/
45 Fuel system too rich or lean
73 random misfire cylinder 3
74 random misfire cylinder 4
Old Sep 8, 2010 | 10:07 PM
Thank you. So how would I go about this? 45 sounda like the simple, diconnect my IAC and adjust the screw for my cold intake.
The other two Im worried about, need to do more research.
Old Sep 9, 2010 | 07:44 AM
EL Vap133's Avatar
Code 73 & 74 could be a variety of things actually. When it happened on my Civic it was a leaky head gasket. Other have just replaced spark plugs, wires, dist. caps/ rotors, etc. and have gotten results. There are quite a few threads about the problem though. Any other symptoms?
Old Sep 23, 2010 | 05:35 PM
Im back:
Just did a compression dry test & they go as:
#1 -165
#2 -150
#3 -150
#4 -156
My check engine code change to 73 & 72
Also, my SRS light is throwing a code; If Im reading right, its a 55.
Anyone know what the SRS error code is?
Gratz
Old Sep 24, 2010 | 12:13 PM
Well. I took my intake oem ram off and had my Throttle Angle Sensor port gave out a laod constent chirp. I may have to adjust my fuel/air mixture. Anyone got the write up for that?
Old Sep 25, 2010 | 11:49 AM
Anyone take a look at compresion numbers, what do you think?
Old Sep 25, 2010 | 01:22 PM
Targa250R's Avatar
be professional
The compression is fine.
You should scan that car with an OBD-2 scanner and get the OBD-2 DTCs (also known as "P-codes"). They're more specific and make it much easier to accurately diagnose problems. The old pre-OBD and OBD-1 double-digit error codes are kind of vague and obsolete.
What problems are you having with the car?
Have you checked the valve lash? Have you ever had the valves adjusted? When was the last time you checked or replaced your ignition parts (dist. cap, rotor, plugs, wires)? Are you getting any oil inside the spark plug tubes? Have you checked for any water inside the spark plug tubes or under the distributor cap? Are you using NGK or Denso spark plugs?
Old Sep 25, 2010 | 03:08 PM
Sordz's Avatar
i would also check the valve lash, should be done every 30k
Old Sep 26, 2010 | 08:54 PM
Thanks for psi feedback, thats a load off my mind. Im getting error code 73,72 and my SRS light in blinking an error code 55. Its been four years since I wrench on my wife CRV. I had a burnt exhauset valve then, and it suck donkey *****.
Today I change the timing belt and water pump, adjusted my valve clearance, and swap out the thermostate. Tomorrow, Im gonna reset the iddle speed, then ignition timing, clean out my intakek, iac, and iddle valve. Hope Im not missing anything. I hope everything will be kewel once I clear the codes and they well stay off.
I will post up the results.
Old Sep 27, 2010 | 08:05 PM
Well, things went very well. She fired up perfect, except for the slight rouph idle and Im still showing error code 73. Not bad, Im down to one issue. Im thinking Im gonna go get rotor, plugs and wires, shes way over due. If anyone thinks Im missing something, this the time let me have it. Thanks
Old Sep 28, 2010 | 07:50 AM
EL Vap133's Avatar
How is your fuel consumption? I have heard that sometimes if you have a leaky injector it can cause those codes to appear.
Old Sep 28, 2010 | 08:21 AM
I would doube check the fuel injectors. Last time I clean them, I had one that had that brown tip broken off and another had hairline fractures. Anyone else?
Old Sep 28, 2010 | 08:56 PM
Well! Jost spent about $82.00 on new dizzy, rotter, wire set, plugs. She started very nice. Cleared the TCU but didnt get a chance to keep at long. Im still shacky about the idle speed. What do the mean by 480/ +50? Is that when i have the iac and canister purg disconected. The tack starts at 500, then u you have the 0. So its 500, 600, 700, 800, 900 and then 1000. So when I hook the iac and the canister, where is theh rpm set at. Im just want get this right, I know its gonna affect my fuel consumption.
jun10r27
Honda Civic (2001 - 2005)
Jan 19, 2009 08:26 AM
That Sob
Sep 2, 2005 09:19 AM
Shakes
Apr 18, 2004 07:20 AM
reVVin
Mar 31, 2002 07:03 PM
