1997 Accord Clutch Fluid Empty???
Old Sep 8, 2010 | 06:20 PM
mwr1964's Avatar
Default 1997 Accord Clutch Fluid Empty???
I found the clutch fluid resevoir empty today. Obviously the car would not go into gear anymore. That is how how I found the fluid empty. I could not find a leak anywhere visible, so where did the fluid go?
Old Sep 8, 2010 | 06:26 PM
F20B_accord's Avatar
Default Re: 1997 Accord Clutch Fluid Empty???
well it doesnt just disappear lol or get used up so you have a leak. you check eveerything? master cylinder? slave cylinder? all lines?
Old Sep 8, 2010 | 06:29 PM
mwr1964's Avatar
The piston that comes out of the master cylinder inside the car is greasy, but it doesn't look like fluid. Otherwise I checked everywhere.
Old Sep 8, 2010 | 06:32 PM
hmm that sounds like a bad cmc, it should be completly dry there, looks like you need to change that out not hard though
Old Sep 8, 2010 | 06:33 PM
does the pedal just drop to the floor with no resistance? fill it up and bleed it than see if it has any resistance
Old Sep 8, 2010 | 06:34 PM
mwr1964's Avatar
Not to expensive either. Found one at a parts store for $25. Just hard to get to the lines on the master cylinder, just from looking at it anyway.
Old Sep 8, 2010 | 06:38 PM
yeah but i always like to make sure its that so whats the resistance like? on the pedal
Old Sep 8, 2010 | 06:39 PM
mwr1964's Avatar
No it has resistance when you press down on the pedal. I did bleed the system and I got a lot of air. Now it is back the way it was, but I am afraid to dive it in case in leaks again.
Now the other thing when I did bleed the system the engine was off. My son pressed down on the pedal I opened the bleeder then closed it and he released the pedal. It did not come back up on it's own when we were doing the bleeding process. He had to pull it back up off the floor.
Once we got the air out and started the car it worked fine. It had resistance and it came back up off the floor on it's own.
Old Sep 8, 2010 | 06:42 PM
hmm well then maybe its ur reservoir, hole in it possibly
mwr1964's Avatar
The resistance seems typical for a japeneese car. I have many 5 speeds, so the resistance to me doesn't feel really hard or soft.
Old Sep 8, 2010 | 06:43 PM
mwr1964's Avatar
There is a lot of free play though and the clutch engages like a couple of inches from the floor, which seems odd.
Old Sep 8, 2010 | 06:44 PM
mwr1964's Avatar
The free play isn't really free play though I checked under the dash and when you press the pedal the piston is really easy to push in for the first several inches then the resistance gets harder.
Old Sep 8, 2010 | 06:46 PM
well free play means time to adjust the clutch pedal!
but for the leak id go from most obvious to least obvious because there has to be a leak somewhere for your whole res to empty.
Old Sep 8, 2010 | 06:49 PM
mwr1964's Avatar
like I said just that greasy stuff coming out of the cmc where the piston goed in. ASgain the free play is not the pedal just moving the piston is actually pushing into the cmc for several inches with little or no effort. So maybe it is the cmc.
Old Sep 8, 2010 | 06:51 PM
ohh okay then yes i had that too, should replace the cmc
Old Sep 8, 2010 | 06:52 PM
mwr1964's Avatar
Thanks for the help. I was kinda hoping it wasn't something serious like the clutch itself.
JoshV1288
19
Jan 26, 2013 02:41 AM
kupras
Feb 19, 2007 09:30 AM
EJ8 GSR-T
Jan 17, 2005 03:41 PM
WiLLMaTiX
May 3, 2004 03:24 PM
94TeGsR
Jan 14, 2003 09:00 AM
