Intake Manifolds
I have a y8 in my car, dunno where/what it came out of and a unknow IM on the car.
My question is, is there a difference in DSeries Manifolds that would cause a massive Vacuum leak?
If the nipple on the top of your y8 IM is plugged, and you still have a massive vacuum leak, depending on your engine, you may have to plug the injector breather holes that are on the face of the manifold. I have a d16y7 with a y8 intake manifold and had to plug those 4 little holes on the manifold in order to get the leaking to stop.
Not sure if this is what you were looking for, but thought I would share.
the leak is around where the flange somewhere, sprayed brake cleaner around it and you can watch it suck it in
im kinda thinking its a gasket
but will check see if i can tell the difference in the manifolds.
4DRmafia
55
Oct 28, 2008 07:11 PM
skate_volcom2006
Sep 3, 2008 05:12 PM
BoostedD15B7
May 16, 2003 06:53 PM
