FS: Factory Oil Cooler
Old Sep 18, 2002 | 10:27 AM
acura_typer's Avatar
Banned
Default FS: Factory Oil Cooler
I am selling the factory cooler setup from a 00 GSR. Comes with the cooler, the long bolt, all the hoses and clamps, water pipe, and the fitting that goes into the block for the return.
No idea what I am talking about? It is #11 in the photo below.
100 shipped for all of it.
I do not need this part as I installed a front mount oil cooler and remote oil filter.
THanks
[Modified by acura_typer, 11:28 AM 9/18/2002]
[Modified by acura_typer, 11:30 AM 9/18/2002]
Old Sep 19, 2002 | 08:11 AM
Banned
Default Re: FS: Factory Oil Cooler (acura_typer)
Still for sale.
Keep you VTEC's oil cool!
Old Sep 19, 2002 | 09:38 AM
Turb0Minnow's Avatar
up for you! that dam thing is expensive from honda! good price bro
Old Sep 20, 2002 | 01:21 PM
Banned
ok, someone make me an offer on it, its damn expensive from Acura/Honda.
Old Sep 20, 2002 | 01:37 PM
itr1244's Avatar
that's ON a stock gsr??
gsr got oil cooler?
huh?
Old Sep 20, 2002 | 01:43 PM
ILUVTEC's Avatar
Default Re: FS: Factory Oil Cooler (itr1244)
Yes, the 94-95GSR's plus TypeR's DO come with factory Oil Coolers, unfotunately my 99GSR does not , oh well when I do my rebuild(build up ) in a couple years I will then add one, enjoy and yes its a good price .
Old Sep 20, 2002 | 01:50 PM
racecarpete's Avatar
Default Re: FS: Factory Oil Cooler (ILUVTEC)
wow you learn something new everyday.
Old Sep 23, 2002 | 10:07 AM
Banned
Actually, my friend's 00 GSR has one. I think only the newer B16s dont have them, BUT THEY NEED THEM. I had an oil temp gauge on my B16A before I put the remote filter and cooler on, and it would peg the needle at 250 (the gauge only went to 250) on the highway or high RPMs. THAT IS TOO HIGH, that is why these coolers should be required for anyone doing any kind of racing.
Old Sep 23, 2002 | 10:12 AM
EF_LSVtec's Avatar
Will it fit a B18a block?
Old Sep 23, 2002 | 10:28 AM
technine's Avatar
My HF comes with the same part on the block! How can you unscrew the old oil filter neck and put that unit on?
Old Sep 23, 2002 | 02:44 PM
Banned
Default Re: FS: Factory Oil Cooler (EF_LSVtec)
it should. look at the back of the block and see if you see a bolt to the right above the oil filter. If you do, the kit will fit w/o modifications. My b16a had the bolt.
Old Sep 23, 2002 | 02:45 PM
Banned
Default Re: FS: Factory Oil Cooler (technine)
You could use a set of vice-grips to get hold of it and turn it.
Old Sep 23, 2002 | 03:23 PM
topspeed86's Avatar
it will work on any B-series blocks with the right coolant pipe, hoses and the adapter bolt.
Old Sep 26, 2002 | 12:24 PM
Banned
back up.
Dkahn18
Jun 24, 2010 04:12 PM
longshot
11
Jan 23, 2009 10:56 AM
PatrickFrantz
Jan 11, 2009 08:51 AM
Chubz
May 31, 2002 02:06 PM
