Would I be able to replace the head gasket on my 95 Civic?
Old Sep 8, 2010 | 06:36 AM
porkyv2's Avatar
Default Would I be able to replace the head gasket on my 95 Civic?
I have a 95 honda civic i bought not to long ago with the idea of swapping out the engine. I then lost my job to long after. Well i just blew my head casket and cars is now parked. My question is my mechanic want to charge me 600 to fix the gasket, but was wondering if its an easy fix that i could do it cheaper. If its not i will be swapping the engine so i need advice on what engine i could swap for cheap that would be worth it. i can spend around a 1000 on an engine. thanks guys.
Old Sep 8, 2010 | 06:50 AM
HarosGSRek's Avatar
Default Re: Need some advice
head gasket for a d series is $30 get a new intake mani gasket. oil. coolant and it takes about 2hrs.
unbolt the intake mani and slide it back
unbolt the exhaust mani and slide it forward
loosen the tensioner
slide off the belt
drain coolant
take off the valve cover
unbolt the head studs.
lift off the head
replace gasket.
reverse order
Old Sep 8, 2010 | 08:23 AM
Former User's Avatar
Default Re: Would I be able to replace the head gasket on my 95 Civic?
Thread titles MUST be subject specific so that members browsing topics can understand the tech problem without reading the post:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Because you are a new member, I edited the title for you this time.
Old Sep 8, 2010 | 09:09 AM
eh9deux's Avatar
Hopefully you won't need any resurfacing on the block.
Old Sep 8, 2010 | 11:25 AM
jyacoba2009's Avatar
when you take the head off, check the surfaces to see if its not warped or still in specs. If so, slap on that gasket and be with it.
Old Sep 8, 2010 | 12:00 PM
roadsqueegy95's Avatar
Buy a helms manual, and follow it step by step. Take your time, and i dont see why you couldnt. I replaced a few before, and as long as you take your time, its not real hard.
Old Sep 8, 2010 | 12:19 PM
noz79's Avatar
Its easy for alot of us but for a complete noob it can be tough. If you know someone that you can ask questions to in person and can tell you what your doing wrong in person, then yea. If not, honda-tech is good but can only take you so far. The Haynes manual is not a bad investment.
Old Sep 8, 2010 | 12:27 PM
vitamin_c95's Avatar
sure you *can
you need a decent tool set and some sort of manual to follow. Are you mechanically inclined? Every response above here has valuable info
Old Sep 13, 2010 | 06:20 AM
porkyv2's Avatar
thanks for the help guys
Old Sep 13, 2010 | 06:58 AM
You replace it? or not yet?
Nocturnal
34
Oct 17, 2023 04:04 PM
NZuercher
Engine Machining & Assembly
10
Jun 6, 2015 08:42 PM
E-AH driver
Classic Hondas
Jan 23, 2012 03:53 AM
elmejor
Jul 17, 2009 03:45 PM
TravisCadello
17
Apr 10, 2009 11:29 PM
