Garage cleanup. b18b1, lsvtec kit, knock sensor, ACL race main bearings, ect. ect.
Old Sep 7, 2010 | 07:46 AM
cruizinmax's Avatar
Default Garage cleanup. b18b1, lsvtec kit, knock sensor, ACL race main bearings, ect. ect.
I need to clean out my garage and get rid of a lot of this stuff to free up some space. Discounts will be given to people purchasing more than 1 item and I am flexible on the price of all of this. I really just need to get rid of it. I will post picture up asap. If interested call or text 4178804584.
http://s1011.photobucket.com/albums/...0sale%20items/
99 integra gsr intake manifold- This is the dual stage manifold with the butterflies. I will include everything to make the butterflies operate ie vacuum canister, solenoid, check valve ect. I will also throw in the throttlebody pulley, spring, throttle cable, throttle cable bracket and a cut intake tube. $40.00
Ebay brand rear camber kit- this is new, never been used. This should fit 88-00 civics and 90-01 integras. Please check for fitment before purchasing as there is no returns. 20.00
ACL race main bearing set and thrust washers for D/F/H series. Part number 5M1957H-STD for the main bearing set and 1T1957-STD for the thrust washers. Fits D16A1/D16A6, D16Y5/7/8, F23A1/4/5/7, H22A4 -$40.00 for all
96-01 integra clutch slave cylinder line-$5.00
96-00 civic brake booster-$5.00
96-00 civic a/c bracket-$5.00
Stock Integra GSR exhaust manifold. I believe this a obd2a manifold as there is no bung for the o2 sensor. SOLD!
1999 Integra LS engine b18b1- this is 95% complete, however it is currently disassembled. The block was cleaned and new main bearings installed. The rods and piston are currently not installed in the block. The rods do have arp studs installed in them. The only thing keeping this from running would be electronics and a head gasket. Everything else will be included. SOLD!
b series vtec knock sensor. round plug style. SOLD!
Golden eagle LS/Vtec conversion kit- This is the complete lsvtec kit minus the headgasket. All the parts will be included. Oil sandwich, oil line, tap for the head, and plug. ect. I will also include all the parts needed to add a PCV system on an obd2 block. SOLD!
I would be willing to trade for some of these items if you have them
-wideband setup
-aftermarket header for b series or jdm Integra type r header
-hondata s300
-cash
Old Sep 7, 2010 | 08:09 AM
Rtboy10's Avatar
Default Re: Garage cleanup. b18b1, lsvtec kit, knock sensor, ACL race main bearings, ect. ect
ill give you $20 for the knock sensor, I owe a member on here one please lmk asap
Old Sep 7, 2010 | 09:21 AM
cruizinmax's Avatar
Sounds good. PMed
Old Sep 8, 2010 | 07:56 AM
cruizinmax's Avatar
up
Old Sep 9, 2010 | 10:36 AM
cruizinmax's Avatar
up
Old Sep 9, 2010 | 04:16 PM
slostjoe's Avatar
Bump for a A+ guy!!
Old Sep 11, 2010 | 09:28 AM
nonpoint986's Avatar
do you still have everything to put the motor back together? the stock ls?
Old Sep 12, 2010 | 09:44 PM
cruizinmax's Avatar
The only things needed to assemble the engine would be a timing belt, head gasket, valve cover gasket. To run it would need injectors, throttlebody, and a distributor. Everything else is included minus maybe 5-6 random nuts and bolts.
Old Sep 13, 2010 | 10:00 PM
cruizinmax's Avatar
updated post/prices
Old Sep 18, 2010 | 07:35 AM
cruizinmax's Avatar
up
Old Sep 25, 2010 | 06:02 AM
cruizinmax's Avatar
up
Old Sep 27, 2010 | 09:42 PM
cruizinmax's Avatar
up
Old Oct 1, 2010 | 10:12 PM
cruizinmax's Avatar
up
Old Oct 3, 2010 | 06:12 PM
rndmheroxx's Avatar
bump for good seller!
Old Oct 3, 2010 | 11:33 PM
cruizinmax's Avatar
thank you sir.
Old Oct 11, 2010 | 03:17 PM
cruizinmax's Avatar
Much offers, no monies yet though.
Old Oct 27, 2010 | 05:56 PM
cruizinmax's Avatar
Finally got some stuff sold. Updated original post.
F22Master
Transmission & Drivetrain
Mar 31, 2014 08:57 PM
JDM346
May 7, 2013 03:08 PM
cruizinmax
Jan 14, 2011 11:44 AM
7rrivera7
Jan 12, 2007 02:49 PM
