clutch feed back ??
im on the search for a DAILY drive clutch for a GSR and came accross some brands that haven't heard before so if any body had used them or currently using one let me know your experience with that clutch
1. exedy stage 1
2.F1 racing clutch
3.XTR clutches
thanks for the imput
1. exedy stage 1
2.F1 racing clutch
3.XTR clutches
Its pretty hard to go wrong with Exedy, they are Honda's OEM supplier for clutches (as well as pretty much all japanese automakers and several domestic companies)
go for the f1 and xtd!!! jk...go for exedy. if you get f1 or xtd you'll either be replacing the clutch within a year or even a few months or you replace the clutch right away because they are known to crack and f* up on you. why go cheap on something so important to power/torque
If you want a bit more agressive feel the exedy stage 1 is awesome, the exedy oem is flawless as well. If you ever plan on modding look into the "exedy smoker" made by competition clutch.
it you want an affordable clutch upgrade which is not too pricey...
you can use this kind of setup for DOHC b16/b18
b20/crv gen 1 clutch disc oem fcc (fcc is the brand name of our oem clutch assembly..)
b16/b18 pressure plate
b16/b18 release bearing
Type R flywheel b16b/b18c or aftermarket flywheel
hope to help!
correct me if there's wrong thanks!
hope to help!
exedy is definetly on the top of the list but for the f1 yeah my brother an my boi had to replace there within 1year...i don't really know though mine has been treating my good for the last 2 years with my beatin the **** out of it...well gl man...EXECTY deff..
hope to help!
hope to help!
interesting , any bidy backs this up ?
DC5KING
11
Feb 17, 2012 10:29 PM
