cel 43 and 1
Old Sep 6, 2010 | 10:37 PM
bLu92bUbbLe's Avatar
Default cel 43 and 1
ok...so I did a little research about the cel 43...people say change the o2..ok my question is can the o2 stop the car from running? it used to start right up...then it went to startin only if I had my foot on the gas...it used to ride perfect...then it went to damn near cutting off at lights and stop signs..i had to keep my foot on the gas wen I stoppd to make sure it stayed on...from 0 to 3000rpms it rode like ****...after that it rode fine...
now when I go to start it...i gota stomp on the gas and damn near hold the key til the battery almost dies for it to start...when it does start and I go to put it n gear the car dies out...idle drops as soon as I put it in gear...please help...stock d16z6 automatic...brand new fuel filter..also changed the relay many times
Old Sep 7, 2010 | 12:31 AM
DRformance's Avatar
Default Re: cel 43 and 1
change the o2 sensor
Old Sep 7, 2010 | 05:37 AM
Sr420Det's Avatar
Code 43 is fuel supply system. Maybe ur fuel pump is takin a dump or Check fuel pressure, mayb change fuel filter.
Old Sep 7, 2010 | 05:42 AM
Former User's Avatar
Check the fuel pressure regulator and whether unplugging the O2 sensor eliminates the performance problem.
Old Sep 7, 2010 | 06:18 AM
I changed the filter yesterday...still the same...guess ill try the regulator...i unluggd the o2 once b4 thinkn it would wrk...still nothing
Old Sep 8, 2010 | 12:17 PM
regulator seems to be fine...pressure is at 41...
Old Sep 8, 2010 | 12:18 PM
and unpluggin the o2 made no difference
Old Sep 8, 2010 | 12:44 PM
With the engine idling, what was the fuel pressure with and without the vacuum hose to the FPR connected?
Old Sep 9, 2010 | 07:16 PM
o sorry...yea the pressure was 41 with the hose connected....im gonna try and start it in the am and see what its gonna be with the hose off
Old Sep 9, 2010 | 07:27 PM
Be sure to pinch the FPR hose after it's disconnected to avoid a high idle.
91blackEF
Apr 5, 2021 03:23 PM
eskimo10
Jul 21, 2009 07:45 PM
eh2ner
15
Mar 12, 2009 03:14 PM
Defiant_dc
Oct 12, 2008 08:29 AM
str8JDMteggy
Jan 28, 2007 11:23 PM
