Starting my LS/Vtec project
Last friday i picked up a B18B short block from a local junkyard for $50. Here is my basic LS/vtec project for now.
Block:
Hone all cylinders
P30 pistons (?)
New OEM Bearings
Type R Oil Pump
Type R Oil Pan
Golden Eagle Conversion kit
ARP Bolts
Head Cylinder:
B16 Head with everything
OEM Dizzy
NGK spark wiring set
Transmisson:
I do a lot of city/highway driving so I guess i will go with GSR tranny?
ECU:
P73
That's all the basic list i wanna do for now. I will just do a lot of cruising around the city. And also which OEM piston is the best? I wanna have at least 12.0 compression or higher. Also im thinking about polishing the block and head cylinder
Block:
Hone all cylinders
P30 pistons (?)
New OEM Bearings
Type R Oil Pump
Type R Oil Pan
ARP Bolts
Head Cylinder:
OEM Dizzy
Transmisson:
ECU:
P73
you're in the right track, my friend. I've gone through 2 LSVTECs, the first one blew up due to my GF driving through a puddle and hydrolocking it. But I have almost the same exact setup as you. The first one I had a b16 head, now I've got a GSR head (not a big difference other than choice of intake manifolds) P30 pistons are great, i have 12.0 compression paired with Buddy Club spec+2 cams. As for the transmission, I have a GSR transmission and its AWESOME. Shorter gears than the LS but its great for N/A. If you really want super high compression, go with CTR pistons. They're gonna give you the highest CR out of all OE b-series pistons
I hope you are getting ARP rod bolts. My buddy blew his first lsv because the bolts stretched and facked the crank. He revved it to 8 on the stock block thats why it happened. The rod bolts only cost about 50 bucks make sure you get them.
Another good thing to do while everything is apart is get the rotating assembly balanced for extra insurance. It cost me $200 for my machine shop to do it.
For Head gasket you use the one for the block.
I've had GE headgasket and it leaked. Bought an OE LS one for my 2nd LSV and no more leak. Also if you're using the LS rods, get them shot-peened and buy ACL bearings and ARP rod bolts. If you want to rev the engine high, you'll need all the extra insurance you can get.
CTR pistons will put your CR in the HIGH 13's.. almost 14:1 way too high for DD let alone pump gas.
P30 pistons will put your CR in the mid 12's...too high for DD on pump gas...realistically
PR3 pistons (B16a) will put your CR right about 12:1... which is the highest i would recommend for DD on pump gas.
ITR (p73) pistons on the LS rotating assembly IMO is the killer combo. mid 11's which will give you a great range of cams to choose from and make good power.
All those compression numbers are w/ a b16 head..if you chose to go GSR head they will go up another.2 compression points. Also was figured w/ an OEM HG and no milling or decking done.
Hands down the B16 or ITR tranny will be the best tranny for any NA motor (my opinion) but the GSr isnt bad either. you would be disappointed with the ls gears.
Also why are you considering building a high compression motor, especially 12:1 or over, for a DD that you drive a ton on the highway? Seems like a waste to me. Premium gas, high compression and all the such will just kill your gas mileage as well as reliability.
well he wont DD'ing it.. it will his weekend car only so our friends loves to cruise on highway together but he asked which tranny will be best got city/highway
HUH? the first part of that post makes me dizzy. If i comprehnded this correct if its not going to be a DD car then who cares what tranny, get what you like but the B16 IMO is the best NA tranny available besides the ITR
i don't recommend CTR pistons either. I went with P30 pistons with my lsvtec and am around 12.1 CR. Its a great motor and if you build it right, it's as reliable, if not more than, other Honda engines. OP have you considered getting a GSR or ITR swap instead?
I hope this guys is joking. CTR's in anything besides a B16 is stupid. Pr3 pistons would get his goals perfect and still be safe
