EGR Cleaning Procedures
Old Sep 18, 2002 | 08:41 AM
CaNaBiS's Avatar
Default EGR Cleaning Procedures
What is the procedure for cleaning the EGR valve? ie. tools, chemicals etc...
This is the EGR valve right?
Old Sep 18, 2002 | 09:30 AM
ViZ's Avatar
ViZ
Default Re: EGR Cleaning Procedures (CaNaBiS)
that is it, but i can't answer on cleaning it.. i might just use some carb cleaner but nothing to strong because of the rubber diaphram thing inside of it
Old Sep 18, 2002 | 09:59 AM
Cottonwoodz's Avatar
Clean the EGR valve with carb cleaner, and make sure you get, the hole in the intake manny(EGR vent) were the valve mounts on, it tends to get alot of carbon build-up in there.
Old Sep 18, 2002 | 10:10 AM
CaNaBiS's Avatar
Default Re: EGR Cleaning Procedures (Cottonwoodz)
Cotton,
My EGR may be blocked off with a metal plate between it and the manifold. If so, I am going to take the plate out tonight. I dont know exactly why it was blocked off on my old engine, but the same EGR may have been transferred from my old engine.
Would that be causing my hesitation problems?
Thanks.
BTW, I am taking my car to another shop in the morning that works on nothing but Honda's in an effort to avoid just putting a bunch of expensive sensors on without knowing exactly what the problem. I am willing to bet that it is a faulty O2 sensor though. It has 170,000 miles on it, but it isnt throwing a code.
Old Sep 18, 2002 | 11:20 AM
Smurfylude's Avatar
They have a carb clear for electric parts on the car at Pepboys. It works pretty good
Old Sep 18, 2002 | 01:04 PM
ViZ's Avatar
ViZ
Default Re: EGR Cleaning Procedures (Sushi X)
some people block it off for performance to prevent it from doing its job which can raise temperatures in the intake manifold..
Old Sep 18, 2002 | 01:13 PM
CaNaBiS's Avatar
Default Re: EGR Cleaning Procedures (ViZ)
My underhood temperature is definately very, very hot! I noticed it the other day, but thought it was caused by the headers having no shielding.
Old Sep 18, 2002 | 02:11 PM
H23 Power's Avatar
Default Re: EGR Cleaning Procedures (90hatchforb16a)
part throttle hesitation is usually o2 sensor
Old Sep 20, 2002 | 02:33 PM
Unreasonable's Avatar
Speaking of which, anyone know where I can get one of these plates for a 5G?
Old Sep 21, 2002 | 09:18 AM
fastludeh22's Avatar
Default Re: EGR Cleaning Procedures (preylude)
you make the plate, i used sheet metel from home depot, but some people use red bull cans and such. and the thing i was talking about for you to clean is not the egr, but the vtec solonoid filter, its talked about in the link i pasted on the other post.
TheIVJac|{al
Jul 27, 2013 04:55 AM
jose310
Jan 8, 2009 09:35 AM
vxnine
Sep 3, 2006 06:04 PM
petrv
Aug 26, 2005 02:26 PM
Cyber ITR
Nov 21, 2004 06:26 PM
