quick question RAD FAN wiring
Old Sep 6, 2010 | 11:39 AM
b20vtec91DA's Avatar
Default quick question RAD FAN wiring
wired my rad fan to the accessory plugs above the fuse panel in my 90 DA and it was working fine when i had it connected to the "ignition on" switch, but after a test drive and parking it, i seem to have no fan. if i blew something, what and where would it be? going to try a different spade and see what it does but im not sure what and where i couldve blown since i did not add a Fuse block.
Old Sep 6, 2010 | 12:44 PM
Default Re: quick question RAD FAN wiring
http://forums.g2ic.com/showthread.ph...ck-panel-fuses
using that picture, and seeing what the spades are labeled. youll know what im talking about. i used "E" to begin with, and now thats not working. i did a continuity and resistance tests on my switch and wiring, and everything checks out. i now have it plugged to "D" and it seemed to last thru my test drive. but seing as how that "E" plug is blown, how do i fix that?
Old Sep 6, 2010 | 01:48 PM
bumppppp anyone? sorry i would post on g2ic but i havent been a member there long enough to post :/
Da Shiek
Dec 31, 2016 10:59 AM
spoolin_teg
Mar 15, 2007 07:21 PM
HxCforever
Mar 10, 2006 05:52 PM
Linh.
Dec 24, 2005 07:11 AM
