b18b swap!!
Old Sep 18, 2002 | 07:59 AM
boonacka's Avatar
Default b18b swap!!
wondering if anyone has a write up or knows a site that goes through a b18b LS swap into a 96^ civic hatch.- thanx
Old Sep 18, 2002 | 04:11 PM
hydroflip's Avatar
Default Re: b18b swap!! (boonacka)
plug and play if its obd2
Old Sep 18, 2002 | 06:22 PM
boonacka's Avatar
Default Re: b18b swap!! (hydroflip)
what about axels , ecu, and so forth
Old Sep 18, 2002 | 06:54 PM
VTECVillain's Avatar
If you get a full drop out OBDII setup it will all bolt up - axles, ecu, motor - all of it. It's just like replacing the stock engine. Wiring will be minimal if any - you'll just transfer your motor's harness onto the LS motor.
Old Sep 23, 2002 | 12:57 PM
boonacka's Avatar
Default Re: b18b swap!! (VTECVillain)
i read somewhere that on the 96 up civic hatchs you have to use the crv or si rear engine mounts to use a bseries motr
Old Sep 23, 2002 | 03:04 PM
AB16A2T's Avatar
http://tech.hybridgarage.com/tech/6gtech/index.html
Check out this page.
Old Oct 5, 2002 | 09:18 PM
DX187VTEC's Avatar
Default Re: b18b swap!! (AresB18BTurbo)
I have a 00' Ls swap waiting 2 be dropped in, i believe you need a 99'-00' Si power steering hose along with the 99'-00' rear mount and i dont know what year motor your dropping but mine i had 2 get a 99'-00' Ex harness 4 the Distrib plug cause mine is bigger then the 00' distrib....I would go with a p74,p75 obd1 w/ a jumper if your obd2 thats what im waiting on personally till i drop mine....
YodajdmEK4
Apr 27, 2006 10:51 PM
silver_96_teg
May 10, 2005 09:29 AM
ted
Dec 30, 2004 09:36 PM
Midwestrider
Nov 11, 2004 02:24 PM
GeekinEK
Feb 6, 2004 05:27 PM
