I Beams in d16a6 block
Old Sep 6, 2010 | 05:08 AM
acro1010's Avatar
Default I Beams in d16a6 block
Do you or do you not have to notch the block when using I beams?
Old Sep 8, 2010 | 03:02 PM
acro1010's Avatar
Default Re: I Beams in d16a6 block
I have heard NO so far/ What have you guys heard?
Old Sep 14, 2010 | 05:09 PM
acro1010's Avatar
any takers????
Old Sep 14, 2010 | 06:32 PM
Adamvanxxx's Avatar
The company usually states if they do or not. Your question is very vast with no details. That's most likely the reason for lack of input.
Old Sep 15, 2010 | 02:18 PM
acro1010's Avatar
my question is not vague i am guessing no one uses these at all. most people think that using h beams you'll have the best which is true, but that is over kill on a d series motor. unless you are one of the elite that are getting the hallowed 500+ out of their motor. i was hoping there was at least ONE person here that uses a d series motor and has used i beams. i have a d16a6 block can you use i beams without notching the block. that is all the info anyone should need. i am not trying to be rude, i am sorry if i am, i can't seem to get an answer. i just get these million plus posters that still know nothing.
Old Sep 15, 2010 | 02:49 PM
MitsuChevyHonda's Avatar
I beams are stronger than h beams. Your not making sense.
Old Sep 15, 2010 | 02:57 PM
Adamvanxxx's Avatar
Well it's is vague, you are not listing a specific manufacturers I beam rod. I beam is not a brand it's a style of rod.
H2B
14
Feb 3, 2015 07:04 PM
kxrider
K Series
14
Feb 3, 2013 04:30 PM
kxrider
Aug 13, 2011 07:51 PM
JoseCuervo
Feb 14, 2006 02:02 AM
bloopie
Aug 31, 2002 07:19 PM
