95 honda over heating and white smoke in the engine bay
Old Sep 5, 2010 | 11:19 PM
kaos253's Avatar
Default 95 honda over heating and white smoke in the engine bay
hi so my 95 honda just got it need works done some reason the two fans in the front near the front bummer dont work?
i get werid gas milage.?
i put anitfreez in the raditor and it leaks out the drive side of the car?
please some one help me i'm new to working on cars but i know the basic to get by and should be able to learn more.i'm doing all the work myself i could use some help to know what i am doing.
Old Sep 6, 2010 | 12:31 AM
C uR eX's Avatar
Default Re: 95 honda over heating and white smoke in the engine bay
If it leaking from where your side timing cover is then your water pump is a goner. you're gonna need to have that replaced. that's why your car is over heating. now since you're gonna have to replace the water pump, you might as well replace the timing belt and tensioner at the same time. good luck.
As for your fan(s), the slim metal one is for your Air Condition and the bulky plastic one is for your radiator. Now if you're radiator doesn't turn on then it might be one of few reason..
-fuse blown
-relay no good
-ECT plug not connected
-wiring not connected
-fan motor shot
these are just a few reason. and from what you mention that you just got this car and depending on your $$$ budget do a tune up. GOOD LUCK.
Old Sep 6, 2010 | 12:39 AM
kaos253's Avatar
what about the other fan?
Old Sep 6, 2010 | 09:48 AM
Hondatherdm's Avatar
blown headgasket
Old Sep 7, 2010 | 03:15 PM
kaos253's Avatar
for sure thanks guys
Camato
24
Dec 13, 2016 03:21 AM
JDMCivic95EG
15
Sep 12, 2013 12:59 PM
dth0ng69
12
Jan 22, 2009 10:11 PM
cbfrench21
Oct 14, 2005 02:17 PM
Typiko512
Oct 1, 2002 07:31 AM
