piston-head clearance issue
Old Sep 5, 2010 | 02:13 PM
forcefedeg01's Avatar
Default piston-head clearance issue
Here's the rundown on parts. B16A block 81mm, stock rods (arp bolts), RS Machine B16B (PCT) pistons with a OEM honda headgasket and GSR head. My problem is, I torqued the head down using golden eagle headstuds and the pistons are touching the head, thus not rotating. I've seen this done on hundreds of b16's using honda b16b and rs machine b16b pistons and yet to hear any problems.
Would it be the GSR head that is causing this since, from what ive read the gsr chamber is different, or what?
I already did one a long *** time ago and didnt run into problems, but this one is kicking my ***. from what i can tell it looks like its hitting on its piston dome sides ( by where the lil arrow is at and opposing side and nothing else.
Any help would gladly be appreciated. i thought of mayb a lil bit thicker headgasket or maybe b16 head swap.
Help me out HT community i need this engine in asap.
Thanks
Old Sep 5, 2010 | 02:20 PM
SL0WEGG's Avatar
Default Re: piston-head clearance issue
If you're having clearance like that. You're def gonna need a thicker head gasket. Did you ever check piston to valve clearance?
Old Sep 5, 2010 | 02:25 PM
JDM JEFFREY's Avatar
Is this going to be a street motor?
If so would look into getting
Jdm p30 pistons
Ctr pistons are going to be 13+ cr
Old Sep 5, 2010 | 02:51 PM
EG1834's Avatar
Get some clay or some play-doh and apply a layer to the top of the piston. This way you can see where it's hitting and how bad.
If it's bad, you may be better off machining the pistons.
Old Sep 5, 2010 | 03:21 PM
Colt Seavers's Avatar
The piston hits the head because the compression height on a b16a is 20 thousands under the deck and b16b is 30 thousands under the deck, so they stick out of the b16a block ten thousands. Just get a thicker head gasket, and you will be fine.....
Old Sep 5, 2010 | 04:14 PM
well the block did get honed and resurfaced which i know its same as decking it. but the ding bats at the machine shop didnt specify how much they took off which sorta pisses me off. the motor is a friend of mines im putting together but i didnt know if the gsr head with the smaller chamber at valves would matter.
Old Sep 5, 2010 | 06:33 PM
77amc's Avatar
Where did the block come from? Previous knowledge of it?
Over-heated blocks tend to warp an open deck at times.
If they're a reputable shop, they would of told you what was taken off.
Or you may want to talk to the piston mfg and get all your numbers together: Crank centerline, bearing thickness, pin dia, piston compression hieght and measure that against the block from deck to center line. If its' way lower than a stock deck then.. They owe you another block
BUT, try and corner them with that.
E
Old Sep 6, 2010 | 06:10 AM
00Red_SiR's Avatar
All Motor Mentor
PCT pistons don't like GSR heads, PR3 heads tend to be better for that combination. Machine shops only do so much but it's often up to the builder to check all clearances at the time of assembly.
Old Sep 6, 2010 | 06:39 AM
EG1834's Avatar
Did you get a build sheet? There is usually a "deck clearance" specified which is how far the piston is above/below the deck surface. With the stroke, rod length, and compression height that should give you an idea as to how much was milled off of the deck.
Then compare that with how thick the stock headgasket is.
I'm assuming that since you say you torqued the head studs, that you are the one installing the cylinder head. Did the machine shop have the head when they machined the shortblock?
Very good point.
Old Sep 6, 2010 | 07:38 AM
yea they had everything, im the one assembling the motor. ill check how far the pistons stick out the block, cuz it does a lil bit
Old Sep 6, 2010 | 07:41 AM
EG1834's Avatar
From what I've read, the OEM gasket is only about .029" thick. If the piston is set above the deck, you may not have enough piston-deck clearance. Most builders shoot for about .035-.040" with steel rods.
Old Sep 7, 2010 | 03:20 PM
yea the lip around the piston does sit above the deck surface of the sleeves (stock sleeves) but idk how far out yet, havent gotten a chance to get in the garage with workin alot. i would think a thicker headgasket will fix the problem correct? or am i ef'd and cant do anything about it?
Old Sep 7, 2010 | 03:32 PM
raverx3m's Avatar
gsr head quench area is different fron b16/type-r
heres the image( tha arows are pointing to the spots)
and btw, i got a OEM headgasket kit(stoner? or stone)) the headgasket is only .022
Old Sep 7, 2010 | 03:36 PM
EG1834's Avatar
Do you have a deck bridge to measure accurately?
Old Sep 7, 2010 | 03:40 PM
EG1834's Avatar
Yeah, there will certainly be issues if the piston is out of the hole, and the headgasket is only .022" thick.
Old Sep 7, 2010 | 04:39 PM
00Red_SiR's Avatar
All Motor Mentor
The gasket should be .026" thick, crushed. .022" sounds like it's a 2-layer hg before it's compressed.
Old Sep 8, 2010 | 03:42 PM
wth is a deck bridge lol. i've never heard of it.
Old Sep 8, 2010 | 03:43 PM
oem honda purchased 3-layer is what im using
Old Sep 8, 2010 | 04:52 PM
00Red_SiR's Avatar
All Motor Mentor
that should be .029" new and .026" crushed.
Old Sep 8, 2010 | 05:02 PM
EG1834's Avatar
I bought mine from powerhouse tools, which is a division of Comp Cams. IIRC, they're pretty cheap.
Old Sep 8, 2010 | 07:24 PM
raverx3m's Avatar
yea the gasket i got was with the rebuild kit, not OEM honda but said to be to oem specs.
its a 3 layer gasket and i measured it at .022. which is fine in my case i need more CR anyway.
damn those pistons are flat
Old Sep 9, 2010 | 04:54 PM
we'll imma swing by the garage tomorrow and take some pics of it and post it so you can all see. i've put ctr pistons before on b16's like i said before but never ran into this issue. i see how the b18c and b16a heads have different designs now. ive never touched a gsr head before since all ive run into were b16a's to do valve springs and such. ill post pics of it then so you can all see and hopefully help me out. I'm a turbo honda guy and this is the 1st time i run into this with an n/a..
thanks alot tho people for all your comments and helping out btw.
MatHadder
12
Mar 4, 2007 02:59 PM
wreckedagain
21
Dec 15, 2005 12:19 PM
crazyitr
11
Aug 13, 2003 09:48 AM
crazyitr
Jul 24, 2003 05:27 AM
turboex
Nov 11, 2002 11:43 AM
