b18b bottom need to make a decision.... N/A internals
Old Sep 18, 2002 | 06:48 AM
fuguman's Avatar
New User
Default b18b bottom need to make a decision.... N/A internals
i have a bottom from a b18b
no head and one of the rods is bent
i was thingking of going turbo but i sorta like the N/A path
what can do to get somewhere around 200hp at the wheels
i was thinking of getting high comp piston/rods and getting non-vtec head from a b18/b20 and then get crower cams
what compression do i need to get that (ballpark) what piston/rod combo to use and $
oh btw i hate having people do my work so i'm gonna do all my own work. unless its imposible to.
Old Sep 18, 2002 | 07:19 AM
Mikey3000's Avatar
Default Re: b18b bottom need to make a decision.... N/A internals (fuguman)
i think it would be pretty tough to get 200 to the wheels w/o a vtec head, unless you did major/expensive work. you could just get some high comp. pistons, you prolly don't need rods, nice cams and gears (with vtec head), all the bolt-ons w/tuning should get u close to 200 at the wheels.
Old Sep 18, 2002 | 01:30 PM
3rdGteg's Avatar
Default Re: b18b bottom need to make a decision.... N/A internals (Salvatore Leone)
All I have to say is nothing is impossible; you can work on your motor yourself as long as you know what you doing, but if you don't, good luck on firing that sucka up. And you can go as fast as your wallet allows; I've seen 200whp ls with no vtec head; it's possible.
Old Sep 18, 2002 | 05:09 PM
l's Avatar
l
i think it would be pretty tough to get 200 to the wheels w/o a vtec head, .
ummm WRONG
hhahahahaha
friend dyno'd 260hp on JG's engine dyno stock bore/stock stroke LS non vtec
LS with p30 pistons, large cams, 45mm dcoe carbs gotta go
Old Sep 18, 2002 | 05:59 PM
Mikey3000's Avatar
Default Re: b18b bottom need to make a decision.... N/A internals (philmagnavox)
JG has an engine dyno not a chassis dyno. btw JG sucks.
Old Sep 18, 2002 | 06:02 PM
TimoneX's Avatar
New User
Wow I'd love to see that motor. What parts? Cams in particular?
Old Sep 18, 2002 | 08:40 PM
l's Avatar
l
read my post... thats what i said, on JGs engine dyno
im not sure what set up he was running
besides the fact it was stock stroke/bore LS non vtec, Carb'd
The set up i said was just off the top of my head. 200whp is easily attainable NON VTEC
Old Sep 18, 2002 | 11:17 PM
Rob Dizzle's Avatar
dude, can you please go further into detail on how a non vtec engine hit 260whp?
something does not add up here. nitrous?
how is 200whp easily attainable on a non vtec engine?
list some mods on how you can get their easly.
Old Sep 18, 2002 | 11:23 PM
aeolus's Avatar
When Mr. Leone was refering to JG having an engine dyno,i think he was trying to say that fugumanwas asking for 200 to the wheels.Im sure 260 would be in the ballpark of 220-230 to the wheels.And besides....most stuff that i hear that comes from JG doesnt last very long anyway.
Old Sep 18, 2002 | 11:40 PM
Ri5e's Avatar
Default Re: b18b bottom need to make a decision.... N/A internals (aeolus)
Theres a B20 at inline pro that made 170 WHP. Stock block. Just Crower cams in the head. If it had some high compression pistons...200 whp would be easy.
Old Sep 19, 2002 | 05:53 AM
fuguman's Avatar
New User
Default Re: b18b bottom need to make a decision.... N/A internals (4 Stroke)
what are some good quality pistons, and is stil need rods so those too
Old Sep 19, 2002 | 11:47 AM
l's Avatar
l
Default Re: b18b bottom need to make a decision.... N/A internals (C5_ALLMOTOR)
oversized itr pistons, and a built LS head with some huge cams
thank you
IT WAS AN ENGINE DYNO !!!! that means it DYNOS AT THE FLYWHEEL!!! 260 FLY WHEEL HP
Who ever said JG built the motor? I know i didnt
here is what it looks like [img]http://members.aol.com/donsteph29/images/motor.jpg/img]
Old Sep 19, 2002 | 03:59 PM
S13 slide's Avatar
mmmmm is that a custom manafold? who makes it? i've been looking to put a pair of dual mikunis on my ls
[Modified by S13 slide, 1:00 AM 9/20/2002]
Jillianbowman87
16
Oct 17, 2011 01:24 PM
R THIS
Dec 9, 2003 01:24 PM
fuguman
Sep 16, 2002 12:38 PM
fuguman
Sep 16, 2002 12:14 PM
fuguman
Sep 14, 2002 01:54 PM
