1995 dx coupe Radiator leak
ok so in my radiator i fill it with antifrezz right and it spills out on the right side of the motor can you all give me a little help what might that aarea be or if there is hose there?
The water pump has a weep hole and if it leaks, i believe, its time for a new one. Someone correct me if I'm wrong.
My water pump was leaking very bad so i suspect that it could be the seal in the weep hole so i just replaced it and it fixed the leak.
ok great do you suugest any for the car? or just a stock one? and i have a question i was told i'm missing a timming belt or something for my power stearing by a friend but i'm not sure if he know what he is talking about.
ok cool, my car is overheating i just want to make sure that the waterpump can cause that right?
and i was told i need a new air pollution pump? not sure if that goes in a car lol i'm so new to this
ok great bro lol so i now know what two thing i need to buy,me and my friend are going to do this water pump replacement he is teaching me but we need a good guide to make it easyer and so i know whats going on got any suggestions? and can i add you to a friends likes eg9 808?
Make sure you don't make the timing belt tight which will cause premature wear on your water pump.
Doing a proper water pump job includes new timing belt and tensioner but if your friend is experience then he should know what he is doing.
GOOD LUCK AND HAVE FUN!
JDMsalinger
Aug 18, 2013 10:05 AM
misterknowbody
May 24, 2010 06:48 PM
