d16y7 engine/d16y8 ECU in 96 EX: Wire harness/ECU and heater problems
Old Sep 4, 2010 | 09:14 PM
Dstaks716's Avatar
Default d16y7 engine/d16y8 ECU in 96 EX: Wire harness/ECU and heater problems
Hey guys I bought a 96 ex civic 5 spd manual. with a d16y7 in it (NOT Y8 it was swapped) . Ok first of all its using a vtec ecu and y8 harness. Its throwing codes from it It has a y8 manifold installed. Now im wondering if I can just buy the y7 harness and ecu and my problems will be solved? And my other issue is my heat doesnt work inside the car.. ac i gone..but that shouldnt effect my heat. Jusst blows cool
Old Sep 5, 2010 | 05:53 AM
Former User's Avatar
Default Re: d16y7 engine/d16y8 ECU in 96 EX: Wire harness/ECU and heater problems
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
The y7 harness and ECU should solve the code problems.
For the heater, check whether the coolant level is low and whether the heater valve is stuck closed due to a heater cable problem (near front passenger's left foot).
Old Sep 5, 2010 | 01:43 PM
Dstaks716's Avatar
ok thanks...the y7 harness will still work even though i will be using a y8 manifold?
Old Sep 5, 2010 | 01:49 PM
Yes, if your Y8 IM/TB is from a Civic with an auto tranny.
Old Sep 5, 2010 | 02:33 PM
Dstaks716's Avatar
how do I know its from an auto?
Old Sep 5, 2010 | 02:38 PM
It has a 3-wire IACV attached to the bottom of the TB.
Old Sep 5, 2010 | 03:31 PM
Dstaks716's Avatar
OK i took some pics. One shows a 3 wire and 2 wire which one is the iacv. And if its a 2 wire I'm screwed right..then i have to mini me swap, I don't want to so is there anyway I can counter act the problem?.
Old Sep 5, 2010 | 05:50 PM
Dstaks716's Avatar
so i take it i have the 2 wire iacv...now wat do i have to do in order to make it work with the y7 ecu/harness. Please respond in need of awnsers asap
bcm0529
10
Aug 29, 2017 07:13 AM
tank1984
Dec 22, 2011 01:59 PM
jayjay0718
Jul 29, 2006 08:01 PM
projectek123
May 31, 2006 08:17 PM
96CIVICEX
Mar 26, 2004 09:26 AM
