mini-me help..
mini-me help..
well im about to do my mini-me into my 96 civic cx... i just have sum questons b4 i start.. im planning on running a y8 head,y8 IM, y7 dizzy, y8 head gasket, y7 block, stock wiring harness, obd2a to odb1 jumper harness and a P08..my question is will the P08 which is a JDM sohc vtec ecu be a plug and play into my wire harness using the jumper harness? also if its okay to use the y7 dizzy with the ecu?? ne one?? thanks in advance.. also i know i have to run the vtec wire and ol pressure switch.. but will the ecu work with my set up??
Re: mini-me help.. (projectek123)
the ecu should work but i would search a little deeper to see what the proper ecu you should use and which ecu would best fit that motor.
KiNGDEE206
04-14-2014 07:35 PM
uindaway
15
11-04-2012 05:23 AM
dctegls
10-04-2010 05:04 PM
jayjay0718
07-29-2006 08:01 PM
