96 hb - Back Up lights wiring problem
Old Sep 4, 2010 | 08:38 PM
Hondatherdm's Avatar
Default 96 hb - Back Up lights wiring problem
So i have 96 hb, im going to swap b16 and the engine harness i got is from 96 or 98 4door ex automatic, i did all the plugs now for my back up lamps, 1 wire comes from drivers side (yel/red) to reverse switch (on tranny) carrying 12v, now another wire that needs to go to actual lamps is yel/red or grn/blk but i dont see either one, so which 1 do i tap in to?
Old Sep 5, 2010 | 05:42 AM
Former User's Avatar
Default Re: 96 hb - Back Up lights wiring problem
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
The wire running to the lamps is Grn/Blk:
Old Sep 5, 2010 | 08:27 AM
i thought i had good enough title. I know that the wire is grn/blk that goes from switch to lights right? i just dont see it, on which side does it run drivers or pass?
Old Sep 5, 2010 | 09:44 AM
Here's your original title: "Converting harness Q"
It's unclear that you are seeking help for the Back Up Light wires. Better thread title = better and faster answers
The wire diagram I posted shows that the connector for Back Up Light switch on the transmission has two Grn/Blk wires. It's confusing, but one is power from the fuse and the other runs to the Back Up Lights in the rear.
Old Sep 5, 2010 | 10:53 AM
but my engine harness is from automatic so it doesnt have those 2 grn/blk wires, so what i was gonna do is find the wire that runs to back up lamps and just run my own wire from switch to that wire, but i cant fis that grn/black that runs to actual lamps
Old Sep 5, 2010 | 12:20 PM
Tap into the Grn/Blk wire at connector C433:
Old Sep 5, 2010 | 01:38 PM
ok, the whole car is 5sp harness and this connector is for auto, need connector like that for 5sp, i found a green one under glove box and it has grn/blk, so i gave it 12v to see if my lamps light up, nothing. I fix way harder harnesses, this one is ximple but its kicking my ***
Old Sep 5, 2010 | 01:46 PM
If your whole car were converted to the 5-speed harness, then your problem would already be solved. Did you look for the C433 auto-tranny connector below/behind the heater control panel?
Old Sep 5, 2010 | 03:43 PM
the whole car is 5 sp from factory, the only thing is engine harness is from auto. Ya i looked and there is no connector that looks like that
digitalvice
Jan 2, 2015 12:30 PM
egblack94
Acura TSX
Aug 22, 2008 05:03 AM
thoff
Sep 28, 2006 02:20 AM
7808
Dec 26, 2005 11:19 AM
d16efsedan
Apr 23, 2005 05:38 PM
