96 hb - Back Up lights wiring problem
So i have 96 hb, im going to swap b16 and the engine harness i got is from 96 or 98 4door ex automatic, i did all the plugs now for my back up lamps, 1 wire comes from drivers side (yel/red) to reverse switch (on tranny) carrying 12v, now another wire that needs to go to actual lamps is yel/red or grn/blk but i dont see either one, so which 1 do i tap in to?
Re: 96 hb - Back Up lights wiring problem
A good thread title helps you get more responses by letting members know what specific information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
The wire running to the lamps is Grn/Blk:
i thought i had good enough title. I know that the wire is grn/blk that goes from switch to lights right? i just dont see it, on which side does it run drivers or pass?
Here's your original title: "Converting harness Q"
It's unclear that you are seeking help for the Back Up Light wires. Better thread title = better and faster answers
The wire diagram I posted shows that the connector for Back Up Light switch on the transmission has two Grn/Blk wires. It's confusing, but one is power from the fuse and the other runs to the Back Up Lights in the rear.
but my engine harness is from automatic so it doesnt have those 2 grn/blk wires, so what i was gonna do is find the wire that runs to back up lamps and just run my own wire from switch to that wire, but i cant fis that grn/black that runs to actual lamps
ok, the whole car is 5sp harness and this connector is for auto, need connector like that for 5sp, i found a green one under glove box and it has grn/blk, so i gave it 12v to see if my lamps light up, nothing. I fix way harder harnesses, this one is ximple but its kicking my ***
the whole car is 5 sp from factory, the only thing is engine harness is from auto. Ya i looked and there is no connector that looks like that
