Removing the 97R shift knob?
Old Sep 4, 2010 | 11:34 AM
Just a n00b's Avatar
Accident Prone
Default Removing the 97R shift ****?
How exactly do you remove the OEM USDM 97R shift ****? Do you have to take apart the entire center console as described here as if you were going to change the shift boot? Or is there an easier way?
Searched the forums, only got the 'remove shift boot' thread, not shift ****.
Old Sep 4, 2010 | 11:47 AM
bengay's Avatar
Default Re: Removing the 97R shift ****?
it should just twist off from the thread, or it might be held down by a bolt/clip right under the ****
Old Sep 4, 2010 | 11:48 AM
Accident Prone
tried that but either i'm not twisting enough or it doesn't work. and if it is held down by a bolt/clip, would i need to take apart the center console? the shift boot is flush with the base of the ****.
EDIT: is it anything like a prelude shift ****? https://honda-tech.com/forums/honda-prelude-4/how-remove-ths-shift-knob-97-honda-prelude-882951/ if it is, how do i turn that plastic ring? i'm trying and it doesn't really budge.
Old Sep 4, 2010 | 12:18 PM
EFsSuck's Avatar
you rock the boot back and forth pulling down. its clipped into the ****. unscrew the ****. remove front part of center console. undo the 2-4 screws holding the boot in. remove boot and clip it back into the **** and throw it in a spot to save it never to use/see it again LOL.
Accident Prone
NVM I GOT IT
Old Sep 4, 2010 | 01:11 PM
etank82's Avatar
Selling it?
Old Sep 4, 2010 | 02:31 PM
Accident Prone
nah, got a JDM one so just taking it off.
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
Shinbo
Oct 8, 2004 01:27 PM
LudemanDan
Jun 1, 2002 12:51 AM
sexyaccord
Mar 29, 2002 10:39 AM
