Remove shift boot
Old Nov 11, 2005 | 09:21 PM
Hybrid 350GT's Avatar
Default Remove shift boot
Aaarrrggg! Search still isn't working....
OK, how do I remove the shift boot? I have startd to pry the plastic up with a flat head, and it looks like if I just keep using more force, it will come up. I can start to see the edges of where the actual boot is attached to the metal frame, but that frame looks wider than the plastic piece. Is this the correct way, or is there a right/better way. I just don't want to break things.
Thanks, in advance for any help.
Old Nov 11, 2005 | 09:40 PM
Erik95LS's Avatar
Default Re: Remove shift boot (Hybrid ITR43)
If you keep pulling it out that way it will most likely snap/break some of the plastic and there are two screws up in front you have to remove anyway. To take it out you need to remove the whole center console. There are a few threads about this in the search, but since its down right now......
On eitherside of the center console compartment (between the seats) there is a philips head screw and two more under the little pop-out cover undernieth the e-brake handle. With those out, you can lift out the rear section.
Then, there is a screw on eitherside of the front section in the very front of the remaining console. Remove those. Take out your ashtray and you will find two more behind it. With those out you can then pull out the piece the ashtray fits into with the lighter/power outlet attached to it.Then you will find two more screws behind it on either side at the top of the opening you just made.
You can now remove the whole remaining console after removing the shift **** and you'll then see how to easily remove the boot. Hope this helps
I'm bored and feel like helping tonight.
Old Nov 11, 2005 | 09:42 PM
Default Re: Remove shift boot (Erik95LS)
Well that is pretty much the best explanation I've heard. Thank you very much.
Sorry you're bored, but thanks for the help.
Old Nov 11, 2005 | 09:49 PM
Erik95LS's Avatar
anytime. Glad to help.
Old Nov 12, 2005 | 02:27 AM
yellow blur's Avatar
Behind the ashtray there are 3 screws, not 2.
Old Nov 12, 2005 | 05:19 AM
Utilitarian's Avatar
Pm sent. Begin at page 945.
The illustrations should be fairly straightforward.
Edit: I just realized this is for a '97. I'm seven away at #50.
Old Nov 12, 2005 | 08:40 AM
Erik95LS's Avatar
Default Re: Remove shift boot (yellow blur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">Behind the ashtray there are 3 screws, not 2. </TD></TR></TABLE>
you only need to remove the 2 outer ones though. The 3rd just holds the ashtray bracket/slider/rails into the part with the lighter on it.
Old Nov 12, 2005 | 08:43 AM
Oh, I wasn't aware of that. Learn something new everyday.
Old Nov 12, 2005 | 12:00 PM
nholmes's Avatar
Default Re: Remove shift boot (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Pm sent. Begin at page 945.
Edit: I just realized this is for a '97. I'm seven away at #50.</TD></TR></TABLE>
Hey Utilitarian, can you PM me that link please? I need to do this soon as well.
Tu MaDre
Honda Civic (2001 - 2005)
Jan 28, 2007 11:14 AM
dtrtw
Jun 30, 2005 02:50 AM
allmotorls95
Jan 14, 2003 10:15 AM
tremor86
Dec 1, 2002 05:29 AM
Judah
Nov 21, 2001 08:22 AM
