Having some problems see if you guys can help?
Old Sep 4, 2010 | 07:11 AM
MindLess311's Avatar
Default Having some problems see if you guys can help?
Well since this is pretty much the only section i use on here ill post my problems with you guys.
Alright well ive been struggling with my car for a bit now. Im getting a cel 14 when i start the car usually if i shut the car off a couple times and restart it will go away. The cel 14 is iacv or bad ecu. The cars idle is all over some times it will idle some times it wont, or after i do a wot pull the idle will bounce or do what its doing now and sit at like 3k rpms. Ive tried a couple different iacv all seem to do the same thing but i know one is bad but i dont think i have 3 bad iacv, orrr do I? Or am i having a ecu problem ive tried reburning my chip but it makes no difference.
Car is a turboed civic tuned on crome any insight or things to check would be great thanks guys.
Old Sep 4, 2010 | 07:15 AM
hondawhiz's Avatar
Default Re: Having some problems see if you guys can help?
i doubt you have three bad iacv. try swapping out ur computer with someone else. sounds like thats the problem. if not keep us updated.
Old Sep 4, 2010 | 02:12 PM
Ill give it a shot its been an on going problem thats been getting worst and worst. Ill get my hands a on an ecu and report back.
Old Sep 7, 2010 | 07:10 PM
Ended up fixing the problem tried the other iacvs with no luck took the best looking one and ripped it apart rebuilt it cleaned everything put it back in and now its idling close to perfect. I did find some issues with my tune that im going to have to address but as for now the iacv was the problem.
Old Sep 7, 2010 | 07:17 PM
RedneckRicer's Avatar
local guy just had the same issued and a it turned out his converted P06 had a lifted track on the board.
Old Sep 8, 2010 | 04:24 PM
Kind of funny im running a converted P06 in my car also ill double check the ecu also just to make sure there is nothing im over looking but car does seem a lot better now. But thanks for the heads up.
k2day
Nov 19, 2011 09:38 PM
yee SERIOUS
Apr 17, 2006 01:58 PM
AJxr
Dec 24, 2005 05:12 PM
dsadas89das78934
Jan 15, 2004 08:01 AM
stRtypR25
Jan 12, 2003 03:09 PM
