Valve cover gasket wont come off
Old Sep 3, 2010 | 10:33 AM
His_Dudeness's Avatar
Default Valve cover gasket wont come off
Hey guys, sorry if this has already been covered somewhere....
my valve cover was super hardened and I had to use a small screw driver and about 40 minutes to get it off. Now I put some very small scratches at the bottom of the groove.... just going to cross my fingers and hope that doesn't become an issue.
Now I am trying to get the spark plug seals off and they are so incredibly hardened that they are coming off in little pieces(i mean really little) and if I keep using a small screw driver I am definitely going to damage something.
Is there any way to soften the gasket? Any tips? Should I just go to a junk yard and buy a new valve cover?
Old Sep 3, 2010 | 11:29 AM
alvarado626's Avatar
Default Re: Valve cover gasket wont come off
I Used a Soldering Grind Down The Point Like a Plat Screw driver
Just Go Slow as The Heat Work Its Way Out [IMG][/IMG]
Old Sep 3, 2010 | 11:08 PM
sublime423's Avatar
I use a propane torch on the other side of the gasket and then take pliers and roll the gasket up like spagetti.
lkytmr
Jun 14, 2008 05:31 AM
Midori Green
Jun 1, 2007 10:53 AM
-Championship-
Jun 29, 2006 10:59 PM
type Gendy
10
Sep 6, 2003 10:44 AM
FSTRex
Oct 5, 2001 09:07 AM
