need stainless flange welded to cast manifold.
Old Sep 3, 2010 | 08:27 AM
hootiehoo's Avatar
Default need stainless flange welded to cast manifold.
this is what i want. i was here a while ago, and dont quite have room for an adapter flange, but would have room welding the fange to the manifold. flange is the tial stainless flange. manfiold is a high quality cast, and the manufactuer routinley welds wastegate flanges to it.
i was going to try using 309 rod, and tap the welds with a hammer after about an inch, and wait about an hr before i progressed, so about 3 hours total to weld the diameter.
what do you all think?
Old Sep 3, 2010 | 09:19 AM
welfarepc's Avatar
Default Re: need stainless flange welded to cast manifold.
can u try to find a mild steel flange?
i just worry about the stainless expanding and contracting, etc.
ive been lucky so far, with just mig welding cast to mild, pre-heat the cast and go to town with as much wire and heat as my welder can put out.
sorry i wish i knew more about stainless to cast. hopefully an OG can chime in
Old Sep 3, 2010 | 05:02 PM
turbojeesx's Avatar
I'd use some nickle rod, weld it inside and out and you'll be good to go. Let it cool down slowly.
Old Sep 4, 2010 | 06:52 AM
hootiehoo's Avatar
what kind of nickle rod? i went to prax air and they heard of it, but diddnt have it and cant get it. where do you buy it?
Old Sep 4, 2010 | 07:31 PM
turbojeesx's Avatar
You would pickup Ni99 or Ni55 and knock off the flux on it.
I've heard of some using 309l in a pinch (since its cheaper and readily available). I personally don't have experience with using that filler on cast though.
Preheat and postheat in the oven slowly.
Good luck!
Old Sep 5, 2010 | 07:24 PM
55superbeetle's Avatar
Do you have room to bolt on a turbo flange and then weld to that? It could be 3/8 thick and then it wouldn't be permanent or require any special welding.
Old Sep 8, 2010 | 06:15 AM
hootiehoo's Avatar
thats actually what i ended up doing.
the flange warped slightly. i tried to weld it on with the flange bolted on, but i couldnt work the torch in there by the nuts and diddnt want to risk welding a nut on.
i hope it fits!
this is what the manifold looks like thats MADE for the tial housing with the flange machined on the cast manifold. I just got such a good deal on this manifold, i couldnt pass it up. the company doesnt sell the Vbanded manfiold by itself, only the t25 and t3 flanged ones.
TwoKSiR
Jul 25, 2009 08:38 AM
nitroice40
Welding / Fabrication
Apr 6, 2006 03:11 PM
yusoslo
Sep 8, 2004 12:49 PM
paulzy
Aug 15, 2001 05:59 PM
