civic eg turbo help with 60ft times
well to start off iam from the uk
iam in the 11s and need to get in the 10s now
but its my 60ft times letting me down @2.0
iam doing 11.8 @127mph
so any help would be great!
here is my spec
500whp b16a engine on aem, gt30
micky ts 225/50/15 tires
car weighs 980kg
rear suspension up high
iam running a b18c4 think you call it the gsr, s9b box
with quaife lsd
iam thinking of getting some wrinkle walls but dont have a clue what to get and where to get them from!
any help would be great even the smallest!
thanks very much in advanced
kiel
here is my spec
car weighs 980kg
with quaife lsd
kiel
what is the final drive of that transmission because im not familiar with it? maybe some traction bars will help along with a nice suspension setup. and what RPM are you launching at?
wow i ran 10.9 @ 127mph. and the pass left a lot to be desired...
you got the MPH you just need better tires for the application, or maybe better driving???
do you have any video of a pass you have made?
get some slicks from across the pond and good luck.
For the original poster, there are companies that will ship to Europe. You just have to research. I think I got my slicks shipped to Germany from a company on Honda-tech. but that was awhile ago. The Netherlands also has a big Honda following with several tuning shops.
I have a suggestion for your next modification:
https://honda-tech.com/forums/welding-fabrication-53/my-mid-engine-rwd-turbo-crx-2609439/
https://honda-tech.com/forums/showthread.php?t=2609439
I have never seen a track in europe as good as a track in the states especially in Germany. They are not prepped. Either concrete or regular tar with nothing down to help traction. My best was 12.6@122 on 24.5 inch slicks. My buddy ran 11.9@125 on 24.5 inch slicks. FWD gets no love in the European drag scene because of the poorly setup tracks.
that sucks for you, man.
here is a vid of the past
http://www.youtube.com/watch?v=tzDSvsgIQd0
also these are not the mts
these are the toyos
i cant get the mts smoking at all or even spin them long enough to get them warm!
what psi should i be running them at?
i had the
toyo=14psi
mts=12psi
cheers kiel
these are the toyos
i had the
toyo=14psi
mts=12psi
cheers kiel
hey Kiel, I think slicks for us is a no no due to regs etc...
My best is 1.9 60ft and people in america seen to struggle on road tyres too, i dont think we are far off. I think main problem is we have been running on such hot days, Heat soak kills the way my car pulls. Marc
cheers marc it has been hot!
i want to try some slicks just to see waht i can get!
iam looking in to getting some tires now
but iam running 15inch wheels and cant go no smaller cause of my brakes!
now when you say 24.5/9/13
does the 13 mean rim size?
also what would be the best tires to get for 15inch wheels?
thanks kiel
thanks kiel
thanks kiel
thanks kiel
Why not take the brakes off then and stick with the stock set-up for the track? 13 diameter 9 inch wide and overall diameter of tyre is 24.5 you think its hot over here imagine what its like over there
thanks kiel
thanks kiel
Like everyone is saying, run some slicks. A traction bar along with extended ball joints will help. Is your clutch and tranny adequate for running 10's? What I'm trying to get at, are your shifts on point or do you need to upgrade any parts to help?
For example:
http://www.speedfactoryracing.net/st...roducts_id=247
For example:
iam now at
10.5@133
1.6 60ft
ive got m/t 24.5 slicks 10psi
traction bars
and holdong revs at about 6800
any more advise would be great
10.5@133
1.6 60ft
traction bars
HamiltonRex
Jul 17, 2006 09:08 PM
