Changed catalytic converter/exhaust manifold car won't start
Old Sep 2, 2010 | 07:37 AM
civicwbolas's Avatar
Icon2 Changed catalytic converter/exhaust manifold car won't start
I changed catalytic converter/ exhaust manifold combo, now the car won't start. I reused the old O2 sensors. The check engine light is now gone. Can't figure out what the problem is. Do I have to reset the cpu? I could really use the help. Thanks
Old Sep 2, 2010 | 08:16 AM
dpetro1's Avatar
Default Re: Changed catalytic converter/exhaust manifold car won't start
there must be something else wrong. simply changing the manifold would not cause a not start issue.
what exactly is the car doing? is the engine cranking? cranking slowly? not cranking at all? are all sensors plugged in correctly?
Old Sep 2, 2010 | 08:24 AM
Car is cranking, after cranking I get the smell of gas. Sensors are plugged in properly, the wires look like there is no damage.
Old Sep 2, 2010 | 08:27 AM
rickkane's Avatar
Pull the plugs and checked for spark yet?
Old Sep 2, 2010 | 08:30 AM
dpetro1's Avatar
ignition troubleshooting
http://techauto.awardspace.com/ignition.html
did you unplug any other sensors? map, tps, anything?
dylanED6
Jul 6, 2015 06:26 PM
thirdstartz
10
Apr 24, 2012 01:44 AM
Cypher0117
Mar 3, 2010 02:16 PM
B18c1_turbo
Apr 1, 2008 08:38 AM
Arbadacarba
Jul 4, 2003 06:21 PM
