which ecu works?
Old Sep 2, 2010 | 06:07 AM
anthonyelevenEX's Avatar
Default which ecu works?
does anyone know which ecu will work in my 99ex with a b18b1 and still be obd2?
Old Sep 2, 2010 | 06:25 AM
GhostAccord's Avatar
Default Re: which ecu works?
Use an OBD2 P75.
Old Sep 2, 2010 | 11:19 AM
mtber's Avatar
Your 99 ex is obd2b. You will need an obd2b p75
Make sure it is obd2b as an obd2a ecu won't plug into your engine harness.
Old Sep 2, 2010 | 06:25 PM
thanks for all the input people!!!
Old Sep 3, 2010 | 08:24 PM
94EG8's Avatar
Seagull Management
Also remember that OBD2B integra ECUs have immobilizers, you can simply remove the immobilizer but you will be left with a solid CEL for bad ECU which wont pass emissions in several states, you can also have the immobilizer replaced with a dummy unit that will eliminate the CEL. Also remember to repin A16 to A15 for the fuel pump to work, see below:
medijuandc2
Engine Management and Tuning
Feb 28, 2013 03:55 PM
patdow1
Apr 21, 2009 04:35 AM
camelian
May 5, 2006 02:18 PM
totaled
Aug 28, 2003 06:01 PM
lsvtec101
Jan 1, 2003 06:39 AM
