Crx for $100!!
Old Sep 17, 2002 | 10:49 PM
HybriDNA's Avatar
Default Crx for $100!!
I just wanted to post that i just purchased my second project car for $100 with a title! Its a Red 88 HF with no dents on it, the interior is already gutted and has no motor. I have $2,500 to spend on an engine swap that i can Turbocharge in the future. So that means i want to spend $2,500 just on the swap then buy a turbo kit in the future. I plan to use this car for street but mostly for the strip. Please help. thanks in advance.
[Modified by JDMports, 2:55 AM 9/18/2002]
[Modified by JDMports, 12:04 PM 9/18/2002]
Old Sep 18, 2002 | 12:05 AM
Brandon Chun's Avatar
Default Re: Crx for $100!! (JDMports)
D16Z6 or ZC for your price range. Oh btw, I wish I could find a Crx for 100 bucks
Old Sep 18, 2002 | 12:18 AM
tysf's Avatar
Default Re: Crx for $100!! (Brandon Chun)
with 2500 and plans to boost it id be looking at either a B18A or B20
either that or a built D16
id stick with the b series though. running low boost an a b20 should be just as quick (probably faster) than running high boost on a d16 and with high boost levels the chances of breaking stuff seems to go way up
Old Sep 18, 2002 | 07:46 AM
ijjz's Avatar
Default Re: Crx for $100!! (tylerspec)
Depends on which B engine he gets, and what kind of engine management he gets for either or. If he gets the B series and wimps out of the engine management because the swap cost a lot then the D series with good fuel management like zdyne will be able to tolerate a high amount of boost with no problems. As long as he knows or can get the zdyne or any other engine management system tuned properly.
$500 for a D16, $1000 for a junk yard turbo set up (best you can get imo), and $1000 on any engine management system, perfect set up. From other peoples set ups like that you will run about 13-14.5 sec 1/4 but not sure of the turbo sizes.
If you only plan on spending the 25 then D series is a good choice, you might be able to pull it off with only $2500 with the best engine management, but if you plan on boosting with the B series its going to cost a lot more then you'd expect.
Old Sep 18, 2002 | 07:52 AM
johnzm's Avatar
Default Re: Crx for $100!! (ijjz)
i dont think 2500 will get u a good setup for any b series. thats the least amount u need to barely get by on a B series setup
Old Sep 18, 2002 | 09:07 AM
crx(gator)'s Avatar
you need to upgrade your suspension and brakes before you do an engine swap btw...without the upgrade your screwed, the HF hubs have to be changed anyway...
Old Sep 18, 2002 | 09:13 AM
Max_ED9's Avatar
Default Re: Crx for $100!! (crxgator)
but it is a project car so that means you want it pretty fast.... go bseries... i went zc turbo for a while, then a rode my friends crx with b16 turbo and i almost shitted my pants.
Old Sep 18, 2002 | 09:51 AM
martini's Avatar
do you plan on doing any of the work yourself?
If so, I would suggest a slightly built B18B.
Old Sep 18, 2002 | 10:01 AM
l0p3z's Avatar
you're just like me. i got a red 89 hf for $250. but i got the interior, but no engine or frontend. still deciding on the motor, but leaning towards the d16z6. until i come up with the money, i guess i'll be switching back and forth between the d16z6 and the zc.
crx for cheap =
Old Sep 18, 2002 | 07:24 PM
HybriDNA's Avatar
Default Re: Crx for $100!! (l0p3z)
Yeah i live in orlando and its hard to find crx's and hatchbacks for sale even under $1000 dollars, the demand for these cars is pretty ridiculous. Thats why i am taking advantage of this CRX and going to make something of its self!
Oh... and thanks for your imputs guys!! Well,,, I have decided to go with a B20 swap for now but will do a mild build for a turbo in the future.
Old Sep 18, 2002 | 07:39 PM
JDM88EF9's Avatar
I got my 88 civic hatchback DX with all the mods listed below for 300$
Old Sep 19, 2002 | 04:01 PM
Ruby Civic's Avatar
Default Re: Crx for $100!! (C5_ALLMOTOR)
87 CRX SI running w/ shi--- paint but no rust and full interior (xpt radio) = $100 but needed lower control arm, muffler and recycled windshield...
Old Sep 19, 2002 | 10:19 PM
xXsarcasmXx's Avatar
Default Re: Crx for $100!! (Ruby Civic)
since he said turbo LATER, I suggest a b series engine (b16/b20)
dont fall into wanting a couple of tenths right away, go for a bseries now and a turbo later...
mi dos centavos......ehhhhhhhhhhh
Old Sep 20, 2002 | 05:39 AM
kranked91dx's Avatar
d16z6 can do a lot with turbo, but if you plan using it mostly on the track, to get better time, better acceleration and better top speed ( due to the b serie trany ) why don't you build a b20 or at least a b18b
skill178
19
Nov 2, 2011 09:27 PM
foxdecoy
Dec 8, 2008 10:30 AM
crxpro
Nov 26, 2008 02:47 PM
juanchoenuncrx
Mar 16, 2008 10:17 AM
mikelax125
Honda Civic (2001 - 2005)
Sep 27, 2006 08:26 AM
