01 Accord No Dash Lights/Tail lights
So I just got a 01 Accord EX... I went to install an aftermarket cd player into the car.... I used a harness to do this... and I hooked up the orange illumination wire which I have been told is a big no no... Now I have no dash lights or tail lights... I tested all my fuses and all appear to be in good working order.. I have done hours of research on the internet and discovered 2 things... 1 being that the driver's side multiplexer unit may have been fried so I got one from a junk yard but that changed nothing but made my headlights not work either (I didn't get an EX multiplexer so I got that fixed)... 2 Ive heard that it frys the dimmer switch but you can jump two wires to bypass that and have constant on bright dash lights... My problem is I can't for the life of me figure out which two wires to jump...Any help would be greatly appreciated... Thanks
Muse panel under the hood says nothing about a small lights fuse... But I checked all the fuses and they were all good... I will triple check them in the daylight tomorrow to make sure again... anyone else got any ideas if its not the fuse...
hi I recently knocked out my dash and rear lights and was thinking I need a new multiplex unit.. which 10a fuse was it that was causing you the issue?
stuck in the dark and dont like the federation
luke p
luke p
bearstitch
Apr 24, 2016 07:05 PM
tlbounds
Mar 7, 2016 05:56 PM
bennett239
Dec 14, 2015 08:04 PM
fleastang
May 26, 2006 03:38 PM
