brakes
Old Sep 1, 2010 | 04:42 PM
jweeks's Avatar
Default brakes
i changed the brake master cylinder/ booster on a civic sedan, i used integra parts and bled the system I have presure when the car is off but when its on i can hear air leaking and the pedal goes to the floor. does this mean that the booster is bad
Old Sep 1, 2010 | 05:10 PM
beansandrice's Avatar
Default Re: brakes
Did you bench bleed the booster before install?
Old Sep 1, 2010 | 05:30 PM
jweeks's Avatar
Default Re: brakes
i wasnt aware of this can you explain i just installed it and filled the resivor and bleed the system
Old Sep 1, 2010 | 07:28 PM
asianflava's Avatar
Default Re: brakes
I just installed an EX m/c on my hatch, the m/c came with the nipples and tubing needed to bench bleed.
Basically, you thread nipples to the ports and attach fluid lines to them, then you run the lines back into the reservoir. Cycle the m/c piston with a screwdriver which drives the air out of the mc and into the reservoil where it floats out of the system.
Old Sep 1, 2010 | 07:50 PM
littlewagon's Avatar
Default Re: brakes
X3 on the bench bleed.
Old Sep 2, 2010 | 07:40 AM
retro90hatch's Avatar
Default Re: brakes
Since y'all talking about brakes any one know where I can get steel braided lines for my 90 hatch I broke the original ones changing the trailing arm bushings don't want to put the steel lines
Old Sep 2, 2010 | 08:11 AM
asianflava's Avatar
Default Re: brakes
I think I got a set of Goodridge S/S brake lines from an eBay seller.
Old Sep 2, 2010 | 09:00 AM
Default Re: brakes
Is
DriveSlowHomie
Jan 31, 2008 03:14 AM
steronz
Apr 7, 2007 10:22 AM
dng
Jul 3, 2005 09:24 PM
slow4dr
Jun 30, 2003 11:42 AM
Volcom
Mar 16, 2002 09:04 AM
