What's needed for a full b16 swap?
Old Sep 1, 2010 | 04:41 PM
16bek's Avatar
Default What's needed for a full b16 swap?
hi i was wondering if anyone knew what i would need for a full b16 swap? i have an ek hatch and about 2 grand saved up i wanted to buy a full swap. it has a d16y7 in it. i was wondering if i could reuse the mounts, if i need axles, and the wiring can i reuse the harness and run the vtec with the new ecu? also is it a plug and play with the new ecu and the d16y7 harness? and is a b16 a a2 a3 or should i go with a b18c or b20 vtec is mounting and are things interchangeable?
Old Sep 1, 2010 | 05:35 PM
Former User's Avatar
Default Re: What's needed for a full b16 swap?
A good thread title will help you get more responses by letting members know what information you need:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Thread title edited.
jons91ef
Jun 6, 2008 10:48 AM
BMRALR
Jan 25, 2008 06:04 AM
DenzComp
May 12, 2007 09:07 AM
OregonEGHatch
Jul 18, 2006 12:57 PM
nauticapinoy
Aug 22, 2004 06:43 AM
