Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Disconnected PCV fresh air intake and P0171 engine code
Old Aug 30, 2010 | 07:00 PM
ryanw2427's Avatar
Default Disconnected PCV fresh air intake and P0171 engine code
Does anyone know if a disconnected PCV fresh air intake duct would cause the check engine light to come on intermittently and throw the P0171 code for "system too lean?" This has been disconnected for a while, I'm guessing from where we had our oil changed last since they also changed the air filter. It's only been a couple days since I found and reconnected it, but I was interested to hear a technical explanation.
Thanks.
Old Aug 30, 2010 | 07:10 PM
92civlude's Avatar
Default Re: Disconnected PCV fresh air intake and P0171 engine code
Yes. It happens all the time! It sets a lean DTC because the PCM only knows about the air going through the MAF sensor. The air going through that nipple is additional air. the Air fuel sensor sees this as a lean condition and tries to richen the system by lengthening the injector pulse. It gets to the point the system is adjusting the system beyond programmed parameters. The pcm reckognizes this as a problem and sets a code.
Old Aug 30, 2010 | 08:26 PM
brian67's Avatar
Thanks for the explanation.I am new here and was also in search of this explanation.Its good to know.
Old Aug 31, 2010 | 06:05 AM
ryanw2427's Avatar
Thanks a lot for the response! That is very helpful.
Old Sep 4, 2010 | 08:53 PM
soon2bdropped's Avatar
wow. dude right on the money.
bnelson620
Dec 5, 2017 03:39 PM
stemiched
May 17, 2007 09:25 PM
LilRedMachine
Honda S2000
Jul 19, 2006 10:51 AM
BLUE EH3
Mar 30, 2005 01:00 AM
Branew
May 1, 2004 09:06 AM
