code 171
code 171
2006 accord 4 cyl. I changed the air filter and then the check engine light came on with code 171. I cleaned the mass air sensor and the light came on again. What next?
Re: code 171
Check if the air cleaner housing cover was re-installed correctly. You may have left an air gap in the air cleaner housing. Also, check the condition of the air filter gasket to ensure it was not pinched.
Re: code 171
However, a common problem I have found on that year Accord is the air boot cracked and leaking.
(MAF contamination is possible,but he did not mention drivability problems)
Re: code 171
The MAF sensor getting debris from unfiltered air will set that code.
Re: code 171
Yeah,I acknowledged that possibility(slim as it may be)but I have never seen a MAF with debris that didnt have a drivability problem. Id say its almost impossible not to have a drivability issue with a mucked up MAF.
He didnt mention a drivability problem,though I suppose he could have forgot to mention it...
john1233567
10-22-2015 03:05 PM
ryanw2427
09-04-2010 08:53 PM
