Honda S2000 Honda S2000
Secondary Air Injection System Error code fired
Old Jul 18, 2006 | 01:52 PM
LilRedMachine's Avatar
Default Secondary Air Injection System Error code fired
Has anyone had this code fire before? (P0411 Secondary Air Injection System Error ) I just recently had a FIPK (K&N) air intake system installed and now the CEL is on. I have triple checked all the connections and CEL still fires. Anyone have any thoughts?
Old Jul 18, 2006 | 02:47 PM
Nishant's Avatar
Default Re: Secondary Air Injection System Error code fired (LilRedMachine)
vacuum lines criscrossed?
Old Jul 18, 2006 | 02:50 PM
Francesco's Avatar
Default Re: Secondary Air Injection System Error code fired (Mr. Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Nishant &raquo;</TD></TR><TR><TD CLASS="quote">vacuum lines criscrossed?</TD></TR></TABLE>
Old Jul 18, 2006 | 02:54 PM
The whole error is: P0411 Secondary Air Injection System Incorrect Flow Detected. I was thinking it was firing because of better (more air) intake flow. I will check the lines again tonight to make sure they are correct.
Old Jul 18, 2006 | 03:00 PM
Francesco's Avatar
nah, more air doesnt mean much. thats why you have a MAS. Even with an intake, your not going to suck in as much more air as you think you are. the stock intake is very well designed.
Old Jul 18, 2006 | 03:02 PM
Default Re: Secondary Air Injection System Error code fired (FR-MOB: Francesco)
Ok. I will check the vacuum lines and let you guys know how it goes.
Old Jul 18, 2006 | 03:57 PM
hatchblack's Avatar
i had that code on my '00 and had the dealer take the car 4 times before they figured it out (it was right when i bought it, so they had to take it and figure it out to get it inspected!). after going through many parts and crap they figured out that the valve from the air pump to the intake manifold was slightly out of line. i guess it was a little crooked or something in the vacuum line? anyway, they straightened it out and the code went away. make sure you check that valve, and your hoses.
Old Jul 18, 2006 | 04:34 PM
blankslat5's Avatar
yeah i had the same thing happen to me i was cleaning my engine and i must have pulled the vaccum line just a little out of line that went to the air pump. it threw the same code. Check that vaccum line make sure its all the way on the manifold.
Old Jul 18, 2006 | 05:48 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (blankslat5)
like they said check the vac lines.. after that check the plug off the pump behind the bumper too mine was a lil cracked off the plug and was hanging loose..
Old Jul 19, 2006 | 10:51 AM
I checked the lines again and....I had them crossed! I have switched them around and the CEL hasnt come back on (yet/so far). It had came on before within 5 minutes of driving. I have driven for two hours today and it hasnt returned. Thanks to all for your help. You guys (and gals ) rock!
carid
Performance
Aug 19, 2015 04:11 AM
ryanw2427
Sep 4, 2010 08:53 PM
veilside_s2k
Honda S2000
Oct 13, 2007 06:20 PM
tegasaurus
Jul 1, 2005 12:16 PM
BLUE EH3
Mar 30, 2005 01:00 AM
