distributor?
Old Aug 30, 2010 | 06:23 PM
michaelsej1's Avatar
Icon6 distributor?
i have a b16a 2nd gen obd1.think the distributor is going bad.what distributor do i get for that motor?
Old Aug 30, 2010 | 08:07 PM
egsleepercivic's Avatar
Default Re: distributor?
td44u 94-95 delsol vtec, came stock with a obd1 b16a
Old Aug 31, 2010 | 04:21 AM
thanks
Old Aug 31, 2010 | 05:20 AM
habib's Avatar
What is it doin? could save money and find the component in the distributor that is goin bad and replace it like the coil
Old Aug 31, 2010 | 10:54 AM
my rev limit just up and changed.this morning rev limit was normal,but every once in awhile rev limit hits at 7200.my rev launch control is steady at 3700 and once vtec crossed at 4500.lately has been acting fine other then my rev limit.car seems to be running very strong not missing.trying to trouble shoot and figure out what is going on.no check engine codes as well
Old Aug 31, 2010 | 12:44 PM
habib's Avatar
if its just your rev limit that is messing up then that has to do with you ecu
Old Aug 31, 2010 | 04:23 PM
rywire told me to check j1 jumper so i checked that and its fine.they asked if my tach was off?ive owned this car for over two years never had a problem with it.they said i might want to get it retuned.if the check engine light isnt coming on you think it might just need a retune or should i get my p28 socketed and chipped?
Old Aug 31, 2010 | 05:36 PM
VtecSyndrome's Avatar
for the record any 92-95 civic or Integra that came stock with a DOHC vtec motor will bolt right up to your motor. 92-95 GSR and 94-95 Del Sol VTEC are the same
LUKE 92 GS-R
Aug 12, 2008 03:07 AM
jakscivic
Jun 2, 2006 11:08 AM
SL_RICK83
Jan 20, 2006 03:27 PM
VWkila
Aug 8, 2003 03:59 AM
