Tuners help! Misfire between 3-k!>!>!>!
Old Aug 30, 2010 | 02:30 PM
d15bfi's Avatar
Default Tuners help! Misfire between 3-k!>!>!>!
Ok so recently i have been getting a bit of a break up in my race car. last outing at the track it was misfiring as well. The car sits often. It feels to me as the high temps recently have been causing it but i know its not the case. I have tried gaping my plugs fron .018-.026 without seeing much for results, changed cap and rotor, still nothing, it has a after market internal coil from accel which could be crapping out and i guess is my next route. now for the basic setup, d15b vitara eagle setup, C16 stock ignition, tuned at 25 psi, s300, stock head 880's, bre7e plugs, ect. When the car was tuned (morgan from synapse) temps were in mid 40's and very blustery, plugs were set to .022 during tuning. Is there a misfire monitor on the s300 or anything like that? any help would be great, if you need more info/tune calb/datalogs/ lemme know. ill take some vids of it to try and help. thanks in advance guys!!
Old Aug 30, 2010 | 02:47 PM
d15bfi's Avatar
Default Re: Tuners help! Misfire between 3-k!>!>!>!
also if my wideband 02 crapped out would this cause this? before i touch the gas it idles around 14-6 once i bring up the rpms then let off it will go to like 18-19 at idle, i know leaded gas does a number on these sensors so just trying to rule things out.
Old Aug 30, 2010 | 04:16 PM
d15bfi's Avatar
bump
Old Aug 31, 2010 | 08:23 AM
d15bfi's Avatar
bump, could my race fuel have gone bad in a year of sitting? its in vp jugs but stored in my trailer which gets very hot
Old Aug 31, 2010 | 03:11 PM
Ls_dx's Avatar
Yeah the race gas could of went bad. Why not just tune it on some 91 octane.. ?
Old Aug 31, 2010 | 04:57 PM
d15bfi's Avatar
its a strait race car, i have been in contact with my tuner and just sent him some data logs he said he will take a look and go from there, what are symptoms of a bad wideband o2?
Old Aug 31, 2010 | 05:56 PM
d15bfi's Avatar
bump help?
Old Sep 4, 2010 | 05:56 PM
d15bfi's Avatar
Ok so here's an update, found that my fuel had deff gone bad, smelled like varnish, so i have emptied my tank, fuel was deff junk smelled like varnish, poured some 93 in and ran for a while, also took the pump out to examine, was coated thick white i assume from heating up and always running low amount of fuel, so now the miss has gotten worse i feel, it will do it all the way up if you rev slowly, noticed fuel presure on my gauge mounted on the fuel rail was only at about 35 at idle, when you rev up it jumps up slightly then drops alot, also when you prime the pump the pressure jumps to 35 then goes back to 0, doesn't it normly stay primed, holding pressure? so i am thinking i have a fuel delivery issue here, pump maybe starting to go out? (walbro 255) gonna try getting new fuel filter, bad injector possibly? any way to test any of this through the s300? Thanks in advance
Old Sep 4, 2010 | 06:34 PM
d15bfi's Avatar
could a bad dizzy possibly cause this misfire as well?
Old Sep 12, 2010 | 02:28 PM
d15bfi's Avatar
so little update, i have emptied tank, put fresh c16 in, new walbro 255 and sock, new fuel filter, swapped ignition coils, plug wires, still nothing, seems to be happening at any rpm which you hold the throttle at, only when the throttle is being held steady, quick revs are fine with no miss. Is this an injector problem? i have precision 880's P&H with resistor box wired in, resistor box turns on and stays on so i assume nothing there. Fuel pressure with vac line on is around 37 and vac line off around 45. I am stumped here and have a big event comming up in 2 weeks, any help would be greatly appreciated
Old Sep 12, 2010 | 05:07 PM
h22 civic's Avatar
id check injectors
Old Sep 13, 2010 | 06:49 AM
d15bfi's Avatar
How????
Old Sep 13, 2010 | 09:33 AM
95dxsir2's Avatar
what do the spark plugs look like? did you get all the nasty fuel out of the rail and lines?
Old Sep 13, 2010 | 01:45 PM
d15bfi's Avatar
I'm most certain I have gotten all the junk had out, checking the plugs going to be the only real way to tell about the injectors,
d15bfi
Sep 12, 2010 02:27 PM
boostfever
Apr 30, 2010 08:37 AM
dansred2000si
Sep 28, 2008 08:28 PM
Cyber ITR
Sep 22, 2006 12:49 AM
D16z6BoostedEK
Mar 5, 2006 04:08 PM
