CEL code p0451 and p0453
Old Aug 30, 2010 | 01:31 PM
alpha_1's Avatar
Default CEL code p0451 and p0453
I have been doing a lot of research and yet has failed to find the answer i am looking for.
car: 96 civic HB
engine: 00 B16a
ECU: 00 B16(rywire OBD2A to OBDB harness)
my problem is that after i did the swap the code p0451 and p0453 came on. when i clear the code it goes away but after driving the car for a while and parking the car for a few minutes the CEL comes back on. i have replaced all the hoes and the charcole canister and its still throwing the same codes...plese help i have been trying to find a fix for this. i know you could just swap out the ecu and run OBD1 but i don't wanna do that and i don't think its worth changing the fuel tank out. i need another way of getting around this problem...
Old Aug 30, 2010 | 08:33 PM
alpha_1's Avatar
Default Re: CEL code p0451 and p0453
bump
Old Aug 31, 2010 | 03:16 AM
94EG8's Avatar
Seagull Management
'96 civic hatchbacks don't have a fuel tank pressure sensor (i believe EX coupes may have), you will have to add one.
Old Aug 31, 2010 | 02:24 PM
alpha_1's Avatar
ok thats kool...so how do i wire one up? bump if anyone else has another great idea!
Old Sep 1, 2010 | 04:11 PM
alpha_1's Avatar
bump...
Old Sep 2, 2010 | 10:02 PM
alpha_1's Avatar
bump...all them EK swap are not having this issue when BARing the car? if so how did you guys by pass it with the ref and make the CEL go away for good?
Old Sep 3, 2010 | 12:01 PM
alpha_1's Avatar
bump
Old Sep 3, 2010 | 12:29 PM
Former User's Avatar
I presume that you don't like this answer.
Old Sep 3, 2010 | 03:33 PM
EJeff8's Avatar
No, he's bumping for an answer to wire one up.
Old Sep 5, 2010 | 06:24 PM
alpha_1's Avatar
AGREED!....bump i know the write up to this will help many people...
Old Sep 5, 2010 | 11:43 PM
alpha_1's Avatar
bump
Old Sep 6, 2010 | 03:15 PM
alpha_1's Avatar
bump
Old Sep 7, 2010 | 04:19 PM
alpha_1's Avatar
bump
g4384063
Jun 3, 2015 02:45 PM
buls
Jun 12, 2013 03:27 AM
team 15
Nov 15, 2008 06:46 PM
boiek9
Sep 13, 2004 01:42 PM
hatchattak
May 10, 2004 05:44 AM
